Author Topic: Mondo Motos Auxiliary Lights  (Read 30156 times)
« on: September 13, 2012, 01:23:40 PM »
I have been looking for a set of lights for a while that did not require a dimmer and provided excellent visibility to catch the attention of oncoming vehicles.  These were reasonable in price (apx 150.00 shipped with harness, 110.00 w/o harness.  The harness was easy to install but I will be changing the connectors where the harness plugs into the lights out to a better waterproof style in the future.  They are apx. 1040Lm and are not obnoxious to oncoming drivers at night.  I really wanted the Clearwaters but could not swing the 500.00 price tag.  There is a thread explaining them over on the ADV forum (http://advrider.com/forums/showthread.php?t=751838&page=19) so I will let you guys read all about them over there if you are interested.  I mounted them with the supplied hardware to the reflector brackets and it is a perfect fit.  Here are a few shots:
« Last Edit: September 28, 2012, 06:52:59 AM by 556ALPHA »
Offline jaclaw
Re: Mondo Motos Auxiliary Lights
« Reply #1 on: September 13, 2012, 02:54:01 PM »
Nice! I will be taking a look at these,  I have been holding off on these for too long.  Do you have a link for the lights?  Thanks,  Jim
« Reply #2 on: September 13, 2012, 05:30:59 PM »
Cool pic bro!  :chugbeer:
Would be even better if you swap out those dim yellow headlights with an HID kit from A&R...  ;)
« Reply #3 on: September 13, 2012, 06:53:16 PM »
Thanks :)  I have been looking for a while.  I almost pulled the trigger on an A&R kit a couple months ago.  I am going to ride like this and see how it effects other drivers.  I think the contrast may help the aux lights as far as visibility.  I tried changing out my City lights with Ebay Led's but they did not work out too well.  The other concern is the HID modified headlights passing the VA State Inspection.  It has not been a major issue to date but I have read things on the NHTSA site which lead me to believe it may be coming.  I do not think they look too close to see if the Aux lights are SAE or DOT approved.
http://www.8383media.com/nhtsa-warns-against-dangers-of-hid-conversion-kits/
« Reply #4 on: September 14, 2012, 03:38:33 AM »
« Reply #5 on: September 14, 2012, 05:48:57 AM »
I posted the ADV link because it is not on the general site yet.  There is a link on there for early purchases:
http://www.mondomotos.com/product/mm10adv/mm10adv.php
Offline sas mayhem
« Reply #6 on: September 14, 2012, 08:14:05 AM »
These are really nice lights. I put them on my C-10 this summer http://www.zggtr.org/index.php?topic=9315.msg113100#msg113100 and I'm going to order a set for my '09.  He does sell out fast thou.
Cheers
Ron
09 Connie
« Reply #7 on: September 14, 2012, 10:01:31 AM »
Very nice! I may have to have me a set of these.
Offline ljcorby
  • COG#: 9359
« Reply #8 on: September 14, 2012, 10:53:11 AM »
Cheers
Ron
Just checked out the site and they are out of stock....   :o
10 Kawi Concours 14 ABS
« Reply #9 on: September 14, 2012, 06:06:05 PM »
They are out of stock with the kit that includes a wiring harness.   If you are fairly capable with electrical work I would use the money toward a fuse block and wire them yourself.  They still have the lights by them self.
« Reply #10 on: September 14, 2012, 06:07:30 PM »
Cheers
Ron
I almost bought those MM15's but he informed me of these new MM10's.  I think both are nice sets of lights.
« Reply #11 on: September 14, 2012, 08:11:37 PM »
I like those allot....and HID headlights are overrated. ;)
« Reply #12 on: September 15, 2012, 05:03:24 AM »
I like those.  Now that I am back to riding to work in the dark I need to add something to alert drivers that I am not a car very far away, which is what the dual side-by-side headlights can make people think.
I wonder how they would look mounted to my crash bars to make me look closer and wider to the oncoming and side street vehicles I come upon.
« Reply #13 on: September 15, 2012, 06:18:54 AM »
If I did a lot of night driving I would buy some brighter lights, mount them on the bars like you suggested, and install a Skeen dimmer.  Then you could really light up the road when you want.  There are also nice under mirror mounts out there for about 85.00.
http://www.skenedesign.com/lights/IQ_170.shtml
« Reply #14 on: September 15, 2012, 03:38:13 PM »
...... The other concern is the HID modified headlights passing the VA State Inspection.   It has not been a major issue to date but I have read things on the NHTSA site which lead me to believe it may be coming.  I do not think they look too close to see if the Aux lights are SAE or DOT approved.
depends on the inspection station you choose. If you utilize the dealership you purchased from, they will never pimp you out, but using "other" dealers has consequences at times. I have had issues with places in Richmond when I had to scavenge some wire from my driving lights, to do a roadside repair on my C10 generator haness. I never went back to replace it and went for the inspection....they wouldn't pass me because the lights on the vehical, even though "auxiliary". were not operational....azzwipes. I rolled the bike out into the lot, removed the lights, and they passed it..... had an issue once with a truck like that also, and the inspector made a big deal, I simply picked up a hammer he had on the workbench, and smacked each light, removing them from the vehical vigorously, and ripped the wires out and thru them all in his trashcan.....turned and said "get on with the f'n inspection. ::)
as far as the HID's go, they really do not know the difference, they simply check ON-HI-LOW and off. most inspectors have no clue what comes as standard on these bikes in the firstplace....
you'd be more wise to make sure you keep the factory muffler....that IS the next thing they will be hitting up. ;)
Offline Xelvic
« Reply #15 on: September 15, 2012, 08:30:49 PM »
I just ordered those city lights from ebay today. What problems did you have with them and did you find another solution?
2012 Kawasaki Concours 14
Offline OCK913
    • The Orlando Riders Club
« Reply #16 on: September 16, 2012, 12:55:49 PM »
I have had mine in for about 4 months and no issues at all.
            2009 Kawasaki C14 - Black
« Reply #17 on: September 16, 2012, 05:31:00 PM »
I bought these and they would not fit properly into the connectors.  If I pushed them in 3/4 they would work but when fully seated they would go out.  Maybe I just got the wrong ones but I bought from a link provided on the COG site.  Can you provide a link to the ones you bought?  I would like to try another set that works.
http://www.ebay.com/itm/T10-168-194-W5W-White-42-SMD-LED-Wedge-Side-Turn-Signal-Light-Lamp-Bulb-DC-12V-/140791058616?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item20c7cd10b8
Offline OCK913
« Reply #18 on: September 16, 2012, 07:24:16 PM »
I did experience the same thing ... sent you a PM rather than go into all the details in this thread.
« Reply #19 on: September 17, 2012, 05:23:23 PM »
That is pretty cool!  Thanks for the link.
