So I have the front rotor off the wheel. I noticed red locktight which I don't have. Should I go buy some?
What torque spec should I use for the rotor bolts?
EDIT: For clarity, I'm going to summarize this thread in the first post.
1. That red goop on your OEM bolts is NOT, I repeat NOT red Loctite. Do NOT use red Loctite.
2. With your new rotors you should be buying new OEM bolts which comes with the red goop which is NOT red Loctite.
3. If you won't want to buy new bolts, then just use the old bolts with NO Loctite.
4. If you feel you must use Loctite, then buy blue and use it in this case.
5. Obviously, one thing not mentioned in this thread, but mentioned in others, is you must install new brake pads when swapping out your new rotors. Please don't forget that one.
6. Lastly, don't forget to seat your pads by making a few hot stops to heat up your pads.
Carry on.
