The C10, aka Kawasaki Concours - The Original => Accessories and Modifications - C10 => Topic started by: Dan on June 20, 2011, 11:14:28 AM
Murphs,,
Bike is gettin there now...
Just glued mine on yesterday with ABS cement. Looks spiffy.
Where did u get the ABS cement?
Need to get some fender should be here tomorrow...
Gonna take the front wheel off...
ltr
Dan
Any good hardware store has ABS cement. Do not get the cement that does it all or any other cements. Just plain and simple ABS cement.
I removed the fender (easy to do ) roughed up both sides with a fine grit sand paper and applied glue and held them together with tape and something heavy over night. The 2 pieces will in effect be 'welded' together forever.
From Murph' website: While the best installation results will occur by removing the fender, it is an operation that can be done with it in place also. Clean under the back lip of the stock fender, using paint thinner or alcohol. Give the Murphs' Fender Extender a good swipe of ABS glue, let it set for about 45 seconds, then stick it to the fender. The unit is pretty much “stuck" after one minute of holding in place. For best results clamp the pieces together overnight. Full cure time is 24 hours.
I got the ABS cement from Lowes. I think it was about $3.
I cleaned and roughed up the mating surfaces a little, coated it with cement and clamped it into place. I think the label said 2 hours to cure but I left it on overnight since it was rainy anyway. Looks totally stock.
Yeah, like that. (shoulda read the whole post before I chimed in)
That's how I put mine on 7 years and many thousands of miles ago, its still stuck on like it came that way from the factory.
Stuck it on, and just to be safe, after gluing it decided to pop ribot it as well, that baby is going no where....
Looks great, and such an important and not expensive add on. My radiators are smiling....
