The C-14, aka Kawasaki Concours-14, the new one :) => Accessories and modifications - C14/GTR 1400 => Topic started by: Xelvic on March 13, 2013, 05:53:17 PM
So I can't really find a solid answer on where to ground the PCV at. I've read that the bolt for the reservoir was not good. Can I just ground it to the battery? It should be here on Friday and want to install it. My bike is a 2012 C14 that is stock except I pulled the flies. I can't wait to feel the results.
I ground mine in 2 places. One bolt to the frame, and ran another wire from there to the battery. Been 3 years without a hiccup, or corrosion forming at the connections.
I am one of the lucky few I reckon that has had no issues using the reservoir bolt since 2008. Some 52,000 miles, so it must not be that bad ;)
The current will follow the shortest path back to the battery anyway, so yes you can ground to the battery.
+1... no problems been on since '08.
I used the accessory leads in the boot on the left side of the dash.
