Author Topic: 2002 C10 for sale in VA -SOLD  (Read 9378 times)
Offline Caffeinated
« on: August 11, 2011, 07:26:10 AM »
The time has come to let my 2002 Concours go to a good home. It’s in great shape cosmetically and mechanically! I’m technically the third owner, but the second owner only had it a month, and only put 500 miles on it before deciding it was too big. The original owner rode it daily and was an SAE mechanic.
I’ve had it 3½ years and 30,000+ miles.
Current mileage is 81,698. I still ride it, so that will go up slightly.
Here’s a list of the mods that will go with the bike:
  • Steve’s (SISF) Performance Exhaust Cam Sprocket
  • TCro’s stick coils
  • Sonic 1.1 straight weight springs with 15w oil
  • Murphs KB fork brace with tube protectors
  • Murphs KB handlebar risers
  • Murphs black screw kit
  • Rifle base with 19” and 15” rifle shields and the stock shield.
  • Fenda Extender
  • LarryBuck light bar with running lights. On/Off switch below left pocket. Wired to be on with lo beams, and will switch off when high’s are activated
  • Rear license plate LED running and brake light.
  • LED bulbs in main brake light housing
  • Power socket in left pocket
  • Grip Puppies
  • Fuel filter
  • Stock rear rack cover and antler covers
  • NEW sealed battery
Maintenance done:
  • NEW set of Michelin Pilot GT’s (Rear installed at 80,610, Front: 81,088) - 6/2011
  • Replaced front and rear wheel bearings and seals – 5/2011
  • Changed rear shock oil – 5/2011
  • New Thermostat – 5/2011
  • New valve cover gasket and well seals – 6/2011
  • Rebuilt front brake calipers - 2010
  • New water pump - 2010
  • New Petcock – 2010
  • Yearly valve checks/adjusts and carb sync’s
  • All fluids have been recently been replace. Clutch and brake fluid, final drive, and coolant.
  • Oil and filter have been changed every 3-4k using Rotella 5w-40 fully synthetic oil.
  • Other miscellaneous gaskets and other stuff I can’t recall at the moment.
Has it been down you ask? Yes it has, twice. I dropped it in the garage while putting it on the center stand (no bags installed), and broke the left peg (replaced). That drop also broke the very bottom piece of plastic opening on the fairing that the scoop covers and is screwed into on the bottom. I have ABS cemented and JB welded it back together, and you can’t even see it with the scoop installed. Second drop was on gravel with the bags installed. Bag and antler broke and have been replaced. Both times the LarryBuck light bar acted as tip over bars and saved the front fairing.
The bike starts right up and runs great, and will take you cross country without a problem.
I’m asking $2,000
Located in Bristow VA (suburb of DC).
BTW... Givi rack in the pics does not go with the bike. The stock rack and cover will be installed before sale.
Couple of pics below with more here… https://picasaweb.google.com/bristow.craigslist/C10?authuser=0&authkey=Gv1sRgCLjR-rS09_KNvQE&feat=directlink
and here (WV ride last year) https://picasaweb.google.com/bristow.craigslist/Wva_ride?authuser=0&authkey=Gv1sRgCKu1sPbqjfjWTw&feat=directlink
« Last Edit: January 11, 2012, 05:17:05 AM by Caffeinated »
2012 Black Concours 1400
Offline Caffeinated
Re: 2002 Concours for sale in NOVA - $3500obo
« Reply #1 on: August 15, 2011, 01:42:38 PM »
No interest? Too much? obo.....
Offline Caffeinated
Re: 2002 C10 for sale in NOVA - $2999obo-reduced
« Reply #2 on: August 20, 2011, 10:04:36 AM »
Price reduced-$2999obo
Offline Caffeinated
Re: 2002 C10 for sale in VA -reduced
« Reply #3 on: August 30, 2011, 06:34:35 AM »
TTT
Offline Caffeinated
« Reply #4 on: September 13, 2011, 05:43:39 AM »
Damn economy......no one wants a nice 02 to ride this fall?
Offline ATC Buckeye
« Reply #5 on: September 16, 2011, 04:18:23 PM »
Seems you gotta give these away.   I just bought a new bike, but I'm gonna keep my Connie because it's just too nice to take $1500 for.  Mine has similar miles as yours and I think that's what scares buyers off.
Offline Caffeinated
« Reply #6 on: September 21, 2011, 11:11:23 AM »
Yea, too bad riding it lowers it's value!  I may try fleeBay and see if I can get any bite's.
Putting in a brand new battery today if that helps sweeten the deal!
Offline Caffeinated
« Reply #7 on: October 04, 2011, 05:46:24 AM »
New Battery in now. Runs great!
$2,500 OBO
Offline celadonjon
« Reply #8 on: October 04, 2011, 04:44:08 PM »
Any tranny/clutch/drive shaft/rear end maintenance completed?
Offline Caffeinated
« Reply #9 on: October 04, 2011, 05:21:07 PM »
When I put the new tire's on in June, I pulled the rear drive pumpkin, and completely greased all the splines, along with a drive oil change. Also bled the clutch fluid when doing the brakes.
Offline celadonjon
« Reply #10 on: October 04, 2011, 05:34:46 PM »
check your PM
Offline Caffeinated
Re: 2002 C10 for sale in VA -reduced $2000
« Reply #11 on: October 12, 2011, 10:24:00 AM »
Ok...reduced to $2,000, need the garage space.
Offline zsiska
« Reply #12 on: October 12, 2011, 03:08:26 PM »
I wish I had the extra cash.  It is a nice bike.  In case you don't remember I am the one that got the bag from you a year or so ago.  I saw you listed it on CL also.
Offline Caffeinated
« Reply #13 on: October 13, 2011, 05:50:05 AM »
Thanks Zak,  How's that bag working out...get it fixed?
Offline Caffeinated
« Reply #14 on: November 08, 2011, 05:32:30 AM »
Anyone want an early Christmas present for that loved one?  Then this bike would look great under the tree!
Offline ATC Buckeye
« Reply #15 on: November 09, 2011, 11:59:51 AM »
Unbelievable amount of bike here for two grand.  Can't believe it hasn't sold.
Offline TrdLtly
« Reply #16 on: November 11, 2011, 06:54:03 AM »
I would buy this in a heartbeat if we were closer. To bad you can't get a storage unit to put it in for the winter. Should easily get $2500+ in the Spring.
Offline Caffeinated
« Reply #17 on: November 11, 2011, 03:35:18 PM »
Fly-n-ride, and she's your's. I ride year round, so no storage needed.  Try to ride it at least every other week or so.  It looks so sad when I leave on the C14.
« Reply #18 on: November 12, 2011, 02:27:06 PM »
stay positive Chris, it's a good price, and a fair deal, living in Va has it's pitfalls (you can ride anytime...almost), so keep it safe and it will sell....beware of craigslist, make sure of your buyer if you go that route....best of luck on selling it, the price is good.
« Reply #19 on: December 12, 2011, 10:58:37 AM »
This looks amazing for $2000. I would buy just for a loner bike if I lived closer.
