Author Topic: traction control  (Read 3053 times)
Conair
traction control
« on: March 16, 2016, 05:11:57 PM »
Wondering if im doing alot of long distance straight line riding if i can get a few more miles a gallon by disabling the traction control? Not sure if it causes a drag on the bike or only engages when it senses its needed in the curves!
Re: traction control
« Reply #1 on: March 16, 2016, 05:43:46 PM »
Traction control will not affect mileage (MPG) in any way.  It only does something when it is needed (which is very rare).   It will kick in less for curves than for hard acceleration, which causes the rear wheel to break free (depending on conditions, of course).  Generally it is a good safety feature that is best left on all the time.
What will affect your mileage more than anything else will be arerodynamics.  To a much lesser extent- FEAM setting, tire pressures, weight, acceleration, shift patterns, etc.
Offline zarticus
« Reply #2 on: March 16, 2016, 06:33:46 PM »
It works by adjusting fuel, secondary butterflies & ignition so there is NO connection to the brake system at all   :chugbeer:
1986 Honda V65 Magna - Black
1984 Honda V65 Magna - Black
Offline Deziner
  • Phoenix
« Reply #3 on: March 16, 2016, 08:09:19 PM »
Other than the ABS sensors to determine wheel speed differential.   :)
Offline zarticus
« Reply #4 on: March 16, 2016, 09:28:43 PM »
Yes, Correct about the sensors. By brakes I'm talking physical movement of pads to rotors  :finger_fing11:
