The C10, aka Kawasaki Concours - The Original => The Bike - C10 => Topic started by: Motor32 on May 24, 2016, 05:41:49 PM
When I was out riding, when I would take off from a light I'm getting a whiff of antifreeze. After I got home I took off the fairings and let it run looking for any sign of a leak or drip. Nothing was found. This may drive me crazy. In the meantime I ordered new hoses from Murph's. Any ideas or suggestions are appreciated. Thanks in advance.
Check the hoses associated with the overflow tank. Also, check the level to make sure it's not overfilled. While there, verify someone didn't use a screw that was too long to secure the belly pan and wound up puncturing or cracking the tank. How does your radiator cap look? Inspect the weep hole under the water pump. It is very close to the exhaust pipe so if it's only leaking when running, the drip may be hitting the hot pipe. Good luck.
It also could have been from a car near you
year and milage would help a bit, but I'll assume based on another thread you posted about forks, that its pre '94...
by this time, likely the large o ring sealing the 2 halves of the thermostat housing has turned to gooo... they all do...
and will produce this symptom. so will the coolant log o rings... and just about every other seal on the cooling system.
This is a '87. Today I cleaned / degreased everything. Checked all the hoses, the weep hole and every connection of the cooling system. Still nothing spotted. I'll have to keep and eye out until I get my new hoses on.
+1 :goodpost:
Thanks, I just ordered the thermostat and the log o-rings. Murph's saves the day again.
+1 Can't tell you how many times I've panicked over a smell that came from another vehicle.
Were you able to replace the hoses and the t-stat/log o-rings? I did that on my bike and, just like MOB said, the t-stat o-ring was just a mess like it had disintegrated. If you have yet to, use fork oil to lube the o-rings. I did that (thanks MOB) and when I finally got coolant back in the system I had no leaks (not counting the coolant that overflowed from pouring too fast :o).
Everything is on my bench waiting for a free day to get it done. Thanks for the tips.
