The C10, aka Kawasaki Concours - The Original => Accessories and Modifications - C10 => Topic started by: tradrockrat on April 20, 2015, 12:14:43 PM
Decided to just use what was in the garage, so as a result it's REALLY sturdy, and REALLY useless as anything other than a top case mount...lol
Offhand I say you're not going to loose the topcase. :thumbs:
Lol - yeah, I think it's safe to say the rack is up to the challenge
In my opinion you can probably disregard the weight limit of your top case.
HA! My buddy asked me if I thought I used enough filler rod in the welds :o ... I told him this is what happens when you're stuck welding with an oxyfuel rig and have too much time on your hands
Looks fairly robust. So do you drive all the time without the lowers on your fairing?
Well I just got the Bike a few weeks ago, and since we are approaching summer in Texas and the lower plastics on the bike were damaged, I just took them off permanently. I've never owned a full fairing bike except my Yamaha Venture Royale touring bike, so I really don't know what I might be missing by having the lowers removed. I like it this way.
Let me know how it works for you. I am just a little south of you so it will be interesting to hear how it goes.
Will do.
I'm in the process of welding up something very similar. The end result will be a 4 wheeler rack covering the passenger area spanning the width of the bike and hardcases.
Mounting to the bike, any issues or helpful hints that might save me some time? Much appreciated.
I would make it VERY easy to remove. Being able to remove the seat is pretty important.
I like the look of your bike without the lowers. this is my first full faired bike too
(http://i944.photobucket.com/albums/ad290/salnap/Mobile%20Uploads/20150727_074441.jpg) (http://s944.photobucket.com/user/salnap/media/Mobile%20Uploads/20150727_074441.jpg.html)
I removed the factory rack, used nylon spacers and longer bolts. Works fine, but won't stand up to weight yours can carry ;)
I always ride without lower fairing in the summer. It makes a big difference when it comes to temperature. My legs don't get roasted. Especially navigating traffic jams or slow traffic in cities is uncomfortable with the lower fairings on.
When it's colder, I love the extra warmth, and the lower fairing is brilliant at protecting my legs and feet from rain.
Well, I've put about 2500 miles on it this summer, and I am extremely happy to have the lower fairing gone. I have no plans to buy a set and install them for the winter. We'll see how it works.
I've been riding my '92 without lowers for about 2 years now...I like the semi-naked look, but then I like the full-faring look also...if you're going to leave them off, consider moving the radiator overflow tank up behind the battery box like I and many others here have done...looks a lot more streamlined without that plastic bulge at the bottom of the frame tubes...can't remember which bike you have to look for to get the new overflow bottle from, but I can go out and snap a pic for you if you'd like? Got mine off Ebay for (I think) $8...after the switch you do need to pop the seat to check your coolant level, but that's just a key-turn away...
That case mount may just be the strongest part of your entire machine...well done!
Ummmm, Murph's Plates. Very reasonable, easy to install, stick a few washers under the rear bolt to keep the trunk level. Its just too Ez.
nice job. I've been procrastinating about building a rack for my trunk. you've given me the incentive to tackle it this summer, except, I'll be using a stick welder.
