Yeah, I'm familiar with that. Here's what came up:
1.367kg/mm Then they give you all kinds of options but not a spring per se..
Have you changed your fork fluid lately? Ok, I see you're getting ready to do that. I've found that dirty fluid makes the suspension harsher. It did with mine. Course if you want it harsher then you could use the next weight up oil or play with the levels.
What symptoms are you having with the bike that makes you think the suspension needs to be beefed up?
Where are the adjustments set on the front?
BTW, systems are back up and nominal. Insult away... If it goes down again when you try to insult me....what can I say....the system is in self preservation mode.
