Even though I was sick this holiday weekend, I managed to strip off the bike panels and remove all the existing audio stuff from the trunk and battery compartment. Cut off one of the dual antenna mount and run a new dedicated power line to the dash area for the new audio location.
Still need to fix the sidemarker signal lights, burnt out flasher, valve adjust, carb sync and counterbalancer, as well as changing both tires, replacing rear rotor and pads and then buttoning everything back up.
