Author Topic: Rotrex + ZX = Fun :)  (Read 9493 times)
Offline SpazOnaConcours
« on: July 25, 2012, 10:02:40 PM »
Someone requested that I plink a couple pics and descriptions up when I got this thing running.... so here it is. Everything is prototype phase atm; no pretty finished brackets or paint. Dyno work was done up in phoenix @ KMS the other day. For a baseline, a stock '08 model made 140-144 on the same dyno. Still need to work out a few bugs with the belt drive and external bearing support, but it made pretty good gains for just 5psi. With the kinks worked out I'm looking at making 8-10 psi on this motor, 15ish on another motor when I get the funds to build it.
Cheers :)
Re: Rotrex + ZX = Fun :)
« Reply #1 on: May 21, 2013, 07:41:30 AM »
« Reply #2 on: May 21, 2013, 08:00:34 AM »
I feel so slow :o
« Reply #3 on: May 21, 2013, 08:46:35 AM »
« Reply #4 on: August 30, 2013, 01:12:23 PM »
Still plugging away at fuel mapping... bike is alive and well. Just a hair under 10psi at peak (12700) rpm... over 4psi @ 6500. Getting fun to ride. This is a quick shot of a 4th gear pull from a little under 50mph to nearly redline. Not too shabby for a 200lb guy wearing a backpack on an unfaired bike.  ;D
http://youtu.be/r8eqUq2nw10
« Last Edit: August 30, 2013, 04:37:26 PM by SpazOnaConcours »
« Reply #5 on: August 30, 2013, 10:14:21 PM »
 8) :thumbs:
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #6 on: August 30, 2013, 10:51:41 PM »
Is that MPH or KPH? Either way pretty  :censored: awesome.
« Reply #7 on: August 31, 2013, 02:01:45 PM »
It's MPH, about 8-9% off from gearing, speedo error, and tire size. :) Run started just under 50mph in 4th gear.... any gear lower than that and I sometimes have some headshake issues.... I'm ironing that out with a damper upgrade when I can afford it.
Offline tweeter55
« Reply #8 on: August 31, 2013, 06:22:45 PM »
    :hail: That machine is freaky fast! :hail:
« Reply #9 on: September 02, 2013, 02:02:37 PM »
I STILLLLLLLLL feel slow :o
Offline tweeter55
« Reply #10 on: September 02, 2013, 03:33:03 PM »
I thought silver was fast. ;) ;)
Offline galaxieman
« Reply #11 on: September 02, 2013, 06:38:22 PM »
even figuring 10% over on the speedo, that's 50-150+ quick, fast, and in a big damn hurry!
« Reply #12 on: September 02, 2013, 07:24:19 PM »
I've datalogged it in 4th; it pulls from about 5.5K to redline in about 10 seconds, give or take. It does the same thing in 2nd gear in less than 3 seconds. :)
Here's another new one. They're both 2007 ZX-10r's. His is fully faired, Ti-Force full system, and 185lb rider... and starting in FIRST GEAR. My bike only has the nose fairing, I'm about 205-210lbs suited, stock exhaust w/baffles removed, and starting from SECOND gear.
ZX-10R Comparison Pull (Supercharged Vs. NA)
Fun.
« Reply #13 on: September 02, 2013, 07:26:29 PM »
...and thanks for all the encouragement ya'll; it's appreciated!  ;D
« Reply #14 on: January 05, 2014, 04:50:40 PM »
For those who like to follow the mildly insane: I've decided to change up the project a bit. Here's a teaser pic of the new power adder for the ZX-10R. Shooting for 10psi till I get the bugs worked out, and then 16ish once I finish building the spare motor. Note the ultra-short runner design.... with TBC I'm anticipating that I can get a GT28 with the big exhaust housing (.86 A/R) to spin up past full boost threshold before 5.5K rpm on a 10R.
Should be fun........ >:)
« Reply #15 on: January 05, 2014, 04:56:35 PM »
Always good to hear from you, Spaz. Love following your projects.
« Reply #16 on: January 19, 2014, 03:39:46 PM »
...manifold getting closer to complete.... so many projects on the table and progress is slow. :(
« Reply #17 on: January 23, 2014, 03:51:03 PM »
Hehehe, progress. I little port work on the inside and off to be thermal barrier coated. :)
« Reply #18 on: January 25, 2014, 09:03:17 AM »
Wow, again.  I feel slow...
« Reply #19 on: January 25, 2014, 06:15:20 PM »
 :hail: How will you keep the front wheel on the ground?
