2008 non ABS 44k miles. Brand new set of Conti-motion tires and new drive cushions, new battery, braided front brake lines, Brembo front pads and rotors and rear pads. The bike runs great, oil changed every 5k using Kawasaki oil and filter, as well as final drive lube. Cee Baileys Euro Tour screen, heli-bars, shifter bearing kit, 2010 muffler, heated grips, Firstgear 2 zone heated gear control installed, HID w hi and low beam, Throttle meister bar ends w throttle lock, Givi 55 top case with Admore lighting kit, luggage rack and aluminum mounting rack; still have the OEM rack as well. OEM and Kawasaki low gel seats included, as well as the drivers peg lowering kit. Normal wear for the mileage and a few small scuffs on the right side from a parking lot tip over.
Asking $5500
Offers? Tire kickers? Am I that far off?
Spring time is around the corner!
Any interest, questions, concerns?
Located in Plaistow NH
Clean title in hand, I am the original owner.
Thank you for looking!
