More than once I've read posts on C10 forums indicating that lots of folks think they can 'by-pass the J-box' by connecting extra electrical loads (lights, heated gear, etc) directly to the battery.
Slybones first made me aware of the error in this logic on his ZZR alternator upgrade webpage. I've prepared some simple schematics to illustrate his point, which I think is important for C10 modifiers to understand. The 'alternate wiring' mentioned below is described in Slybones' ZZR alternator upgrade page
and on a new page about alternator wiring in general.First two pics, the OEM wiring setup compared to the Alternate wiring setup
with the engine off (or at idle where the alternator output is less than the battery voltage). The current-load connected directly to the battery does not go through the J-box; the J-box is only involved for those circuits that are 'hot' depending on the ignition switch position (clock and OEM accessory leads with switch-off, some lights with switch-on, all OEM circuits with bike running at idle).
Second two pics, the OEM wiring setup compared to the Alternate wiring setup
at 'cruise speed' (engine RPM sufficient that the alternator output exceeds battery voltage. This is where you want to be 90% +/- of the time when riding so your battery stays healthy).
With OEM wiring, the current-load connected directly to the battery comes from the alternator through the J-box;
the J-box is involved in all loads because the alternator output all goes through the J-box.
With Alternate alternator wiring, the alternator output is not routed through the J-box;
the only current routed through the J-box is that needed for loads on the OEM fuse block. Aux loads that are connected to the battery (or the starter solenoid stud) do not go through the J-box, presumably reducing stress on that sometimes problematic component.
The point is to advise folks that with the original alternator wiring they are not 'saving the J-box' by connecting their extra loads directly to the battery. Contrary to what some seem to think, for all practical purposes any added electrical load goes through the J-box when riding the Connie. Nothing wrong with that electrical scheme, I just think folks should know how it really works.
