Author Topic: Gas Cap Key  (Read 2409 times)
Offline SmokinRZ
Gas Cap Key
« on: August 09, 2018, 05:57:59 am »
Hello, I am about to take a week long trip and would rather not fumble with the key in the FOB and would like to keep a key in the glove box of my 08.  Will I have problems finding a key blank at my locksmith or having the key cut from the FOB key?  Thanks
2008 Concours
2005 Concours (gone)
1992 Concours (gone)
1998 R1100GS
Offline fartymarty
Re: Gas Cap Key
« Reply #1 on: August 09, 2018, 10:44:09 am »
I don't think so, I didn't for the gas cap and saddle bags. However most key blanks that match the key profile will have too large of a head to also be used in the stove knob section. If you also want to have a backup for that as well be sure to get out a grinder and test fit the spare key in the stove knob area before you leave on a trip. It was more difficult for me to find a blank for the GIVI top case than for the C14.
There are two different keys used (A & B) so a blank that might work for one C14 may not work for 50% of the rest of them.
You might want to start the locksmith off with one of the below blanks.
 Ilco KW14; Ilco KW14R; Ilco X254 ; Ilco X255; Ilco X258; Ilco X259
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=2ahUKEwjH4fGht-DcAhUOYK0KHeokDaYQFjACegQICBAC&url=http%3A%2F%2Fwww.ilco.us%2Fmedia%2F770046%2Fv4%2FFile%2Fmotorcycle-key-blank-reference.pdf&usg=AOvVaw3OsvUX1406DKX-k2ExG2UE
Offline connie_rider
Re: Gas Cap Key
« Reply #2 on: August 09, 2018, 02:47:02 pm »
I went to a locksmith and had some made.
Not a problem.
Ted
Re: Gas Cap Key
« Reply #3 on: August 09, 2018, 03:23:52 pm »
Not a problem.
Same here.  The resulting key was too big (huge head, sticks way out of the locks too), but works fine.
Shoodaben (was Guhl) ECU flash, Canyon Cages front/rear, Helibars risers, Phil's wedges, Grip Puppies, Sargent World seat-low & heated & pod, Muzzy lowering links, Soupy's stand, Nautilus air horn, Admore lightbar, Ronnie's highway pegs, front running lights, HID, helmet locks, Garmin Zumo 450, Sena SMH10, Throttle Tamer, MRA X-Creen, PR4-GT, Scorpion EXO-T1200,  Tourmaster Flex II
Offline kzz1king
Re: Gas Cap Key
« Reply #4 on: August 09, 2018, 07:50:21 pm »
I had a couple made and cut the heads down and epoxied them in oil cap Lids. I leave  mine in my saddlebags all the time. If I feel I need to secure things were closely I just drop them in the cubby. It's real Handy to reach for one when I fill up for gas.
2010 CONCOURS
1974 Z-1
Re: Gas Cap Key
« Reply #5 on: August 10, 2018, 08:47:00 am »
The key I initially bought from the locksmith was also long like the one that maxtog has.
I went back to the locksmith and he found a shorter blank to use. Works perfectly.
I did the same as kzz1king, but used Radio knobs instead of oil caps.
I suspect we both built them so that they barely stick out of the top of the bags.
Not noticeable at all. I tell folks mine are knobs to adjust the stereo.
        {Surprisingly, most believe me).  :o
I use a leather key case that I put my Fob, lock keys, spare trunk keys, and keys for the gas tank in.
Very handy..
NOTE: I'm always concerned I'll loose my FOB, so In the key case I have a dog tag with a note saying "If found, call ###-#### for $100 reward".
Re: Gas Cap Key
« Reply #6 on: August 10, 2018, 02:46:42 pm »
Not a bad idea, Ted.  Although, with me if you found my fob it would have my pants attached to them.
"LOCTITE┬«"  The original thread locker...  #11  08-C14 EA FC ABS 46 Monitoring with cutting edge technology (sold).  U.N.I.T is Back!  2016 Indian Roadmaster.
Re: Gas Cap Key
« Reply #7 on: August 10, 2018, 05:37:52 pm »
caught in the zipper?
Offline tweeter55
  • Ride Hard...Ride Safe
Re: Gas Cap Key
« Reply #8 on: August 10, 2018, 05:57:19 pm »
First time I've heard it called that. :rotflmao:
Offline katata1100
Re: Gas Cap Key
« Reply #9 on: August 11, 2018, 09:49:59 am »
Local locksmith has blanks that will work, just with different top. I have one from dealer, drilled a hole in it to attach Del Sol ( changes color with sunlight ) key chain.
I keep that in the gas cap on long trips, along with a cc in the glove box.
Offline SmokinRZ
Re: Gas Cap Key
« Reply #10 on: August 11, 2018, 01:26:40 pm »
Thank you for the responses.  I used to carry a spare key zip tied under the side cover of my C10.  I get thousands of miles from home and worry about things like that .  I might do that with a Ford F-150 key since my 08 didn't come with a passive key, just two active FOBs.
2008 Concours
1998 R1100GS
Offline fartymarty
Re: Gas Cap Key
« Reply #11 on: August 11, 2018, 02:04:53 pm »
I know I'm going to be guilty of --->  :deadhorse: :deadhorse: :deadhorse:
..but because there is so much confusion and mis-information around, I will take this opportunity to once again point out what most of you already know....
..that is that both of those active FOBs are passive FOBs as well....I know I know..you already know this..but down the road someone that doesn't will stumble across this thread
about keys and go "HUH? I didn't know that."  So this is a just a in case post.
Offline SmokinRZ
Re: Gas Cap Key
« Reply #12 on: August 11, 2018, 05:15:43 pm »
I was just thinking that storing an active FOB on your bike might not be a good idea  ;D.  Even if theft was not an issue I'm not sure if it was built with the long term elements in mind.
2008 Concours
1998 R1100GS
Re: Gas Cap Key
« Reply #13 on: August 11, 2018, 05:29:06 pm »
I leave mine in the tank bag.
Offline fartymarty
Re: Gas Cap Key
« Reply #14 on: August 11, 2018, 11:53:36 pm »
Understood, and I like your idea and agree with your thoughts. The way you worded it however, might confuse a newb so I was just bangin' on a horse so we don't inadvertently become a part of the
mis-information cycle.
