Author Topic: Tried to replace my C14 battery, then this happened  (Read 2874 times)
Offline mvjr1904
« on: April 06, 2019, 10:31:40 am »
Don't know what went wrong.  I'm no certified mechanic but I think I know how to swap out a battery. I've done it numerous times for maintenance and to connect my battery tender wiring with no issues.  My bike had been sitting and not turned on for several days so I figure it's a good time to swap out the battery.  Attempted to install my new battery, final step connect the "Neg" cable to the frame with the screw.
At this point significant sparking occurs, the screw got extremely hot (I had to quickly let it go) and the "Pos" cable starts to smoke. Removed the battery, reinspected everything.  All looked good, reinstalled battery, same sparking happens.  More smoke, bare wires now visible thru the protective coating on the wire.  At this point I need to replace the "Pos" cable.
Racking my brain on why and don't know why this is happening.  Any advise??
2011 Silver C14 - Fastest
2002 Silver C10 - Fast
Offline Tree
Re: Tried to replace my C14 battery, then this happened
« Reply #1 on: April 06, 2019, 11:10:12 am »
New battery?  Put the battery on a tester.  I suspect all of your "new" problems stem from that, if the battery is new that is.  While the battery is out then check continuity of the positive cable to the frame.  Any more "testing" of that battery will damage it and your electrical system more if there is a short circuit somewhere.
I feel that I need to add a disclaimer and say don't listen to a damn thing I say.  Considering what I have done to my Connie's electrical system in the past.  And the silly thing still runs!
« Reply #2 on: April 06, 2019, 01:03:44 pm »
I would guess that somehow you have a short in your wiring.  To cause sparks and enough heat to melt the cable lining indicates all the current was flowing with no resistance at all.  Test the resistance between the two cables (as suggested) and from positive to frame, if you have no resistance, then do NOT try reconnecting the battery until you can locate the short.
Perhaps over time one of the cables has chaffed and has grounded itself to the frame?  I don't envy your situation because trying to find a short like that is probably not going to be easy.   Since you didn't have the problem UNTIL you replaced the battery, it is likely that the short is near the battery area.
« Reply #3 on: April 06, 2019, 02:32:01 pm »
just tossing a wild guess... but seeing as these batteries do come in Left and Right Positive cable lug variations... are you sure the "new" one is identical to the "old one"..?  and was not overlooked, and installed by "force of habit/mere memory" on the direction it went in...?
check... is there an L in the number? XXX14L
Offline mvjr1904
« Reply #4 on: April 06, 2019, 03:27:43 pm »
Thank you Forum for all the possible "cures".  New battery from the dealer - Yuasa YTX4-BS. Polarity the same as removed battery.
I failed to mention, I reinstalled the old battery to "start over" and the same sparking and smoldering wires occurred.
So.... from the responses submit, I guess I'll have to look at the wiring.
I'll keep you all updated.  Its a Silver 2011 C14 with 39,561 miles. Maybe its time to repair then upgrade. What are the 2019 colors...... just saying......
« Reply #5 on: April 06, 2019, 04:50:44 pm »
Almost exactly the same here.
Nah
Frankenstein  http://www.zggtr.org/index.php?topic=20250.0
« Reply #6 on: April 06, 2019, 05:07:42 pm »
This is very perplexing, especially knowing the wireing, and connections/components from a professional standpoint.
It would take something like a "FOREIGN OBJECT" laying across the terminations at the Main relay (that sits next to the battery", to create a short of the magnitude to actually "melt" a battery cable when it's "connected", like you are explaining. Any secondary circuits are all "cut off" from seeing "current", by that relay.. so only a dead short of that component could cause this. All of the secondary wires, everywhere else on the bike, are small enough to "go poof", and immediately vaporize, when shorted.
Start looking at that relay and base it plugs into, and see if there is a "stray metal object" in there that is causing this short circuit..., a wrench, socket, something substantial that can bear the current to allow the battery cable to "melt".
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #7 on: April 06, 2019, 05:19:36 pm »
I don’t know the routing of the cables but it seems to me trouble started when the negative cable was attached, completing the circuit. Knowing that I would look at the positive cable and maybe some chafing occurred during the process of changing out the battery. Just my $.02 worth.
« Reply #8 on: April 06, 2019, 06:01:54 pm »
ok.
so, if you are not familiar with the wires, and the protective means they are routed in
the attached photo should 'splain a bit more..
disavow the black, and red 10awg wires I have in the photo, that run remotely... they run to my remote fuse box... the "main" power cables run to a frame ground(to the right), and around the battery directly to the Main Relay block(to the left)... very little (if anything, that will melt a batt cable) other than what I mentioned, could be the culprit.
« Reply #9 on: April 07, 2019, 07:27:20 am »
I searched for a Yuasa YTX4-BS battery online but I couldn't find that exact model number. What I did find was a Yuasa YTX4L-BS
If you're using a YTX4L-BS then I think that I know what your issue is.
Offline route66tc
« Reply #10 on: April 07, 2019, 08:22:08 am »
The OP doesn't mention changing out the battery because it was faulty, only because it had not been "turned on".  So I'm gonna assume that there weren't smoking, melting wires and sparks flying before it was touched.  All is well until he swapped the battery.  Last thing touched right?  The insulation on battery cables is pretty substantial, so I'm ruling out that it was chafed during install.  You have to do something pretty wrong to get the display he got when completing the circuit.  I am no electrical whizz for sure, but I think it was hooked up backwards as Conrad is gently hinting at.  Just my opinion and worth what you paid for it.  I really hope he didn't roast something costly.  Good luck feller!
« Reply #11 on: April 07, 2019, 03:32:01 pm »
well, now we have numerous "weird" things....
stock battery "SIZE/RATING" conforms to a commonly available YTX14-BS "package/rating"
not YTX4, L, BS, or anything... that can't be the battery... simply too small...
BM Part #:   YTX4L-BS
Voltage:   12 Volt
Capacity:   3 Ah
Type:   AGM
Length:   4.5"
Width:   2.81"
Height:   3.38"
Cold Cranking Amps:   50 CCA
Shipping Weight:   5.00Lbs
size comparison, and polarity
YTX14BS
YTX14 L BS
size reference
BM Part #:   YTX14AH-BS
Voltage:   12 Volt
Capacity:   12 ah
Type:   AGM
Length:   5.24"
Width:   3.50"
Height:   6.54"
Cold Cranking Amps:   180 CCA
Shipping Weight:   10.40Lbs
as I said before, the battery attaches to the main relay....4 inches behind it... via an 8 to 10 inch long cable...with the bike "turned off" that is the extent of where current, from the battery, thru the cables, can travel to. Period.
« Last Edit: April 08, 2019, 02:45:25 pm by MAN OF BLUES »
« Reply #12 on: April 07, 2019, 03:54:36 pm »
Maybe the op would be kind enough post a picture of his battery compartment as it is right now, like the one MOB posted. Along with a pic of his battery.
Offline route66tc
« Reply #13 on: April 07, 2019, 04:17:39 pm »
Can a defective battery with an internal short create the same symptoms?  If the battery were hooked up backwards, what can he expect when it's hooked up properly?
« Reply #14 on: April 07, 2019, 04:56:13 pm »
that would go a long way to help, for sure, especially identifying/showing the actual wires, and points where "the smoke came out/was released"....(sorry, just a little electrical joke about "the magic smoke")  but pictures would help greatly....
well, short answer, no, the occurrence with an internally shorted battery would not result in that; when a battery shorts "inside" it basically removes the capacity for "full voltage" at the point of the short; There are 6 sets of plates,each supplying approximately 2 volts (=/- a % of that), if a short occurs between the first and second set, the output volts will be like 9-10v, or 2-3v, depending on which end of the stack it occurs to.   If a battery is installed in THIS bike, as long as the ignition is off, minimal sparking will occur at any terminal... and when attempting to start the bike after, it will not start. Removing the battery, and replacing it correctly, works fine; or so we have seen by the numerous reports on THIS BIKE when they have been incorrectly installed (was very common a few years back, to see this occur even from the dealers... :o ), and so far, after reversing the battery, and connecting it right, no further problems of "catastrophic" damage was found. I guess it's a testament to the robust nature, and safety built into THIS bikes design... or, just plain luck.
Now, if a battery with an internal short, is JUMP STARTED, of forced to take an outside current flow, which it now cannot do because of the short... it COULD blow sky high, and at the least, it will melt down the jumper cable in short order, as its basically like connecting the cable ends, from a running engine sending charging current...
I've had to run outside and put someones "burning" car out with an extinguisher at work, when they attempted jumping a shorted battery... it was pretty impressive to see how fast things "went south"...
