Author Topic: Radar detector won't stay plugged in. Loose fit accessory 12v socket.  (Read 21704 times)
Offline Steve Poff
I've tried using my Escort 8500 plugged into the accessory socket on the dash but the plug won't stay in place for more than a minute or two.  I've anchored the cord close to the socket but that didn't help.  Has anyone else encountered this problem and, if so, how did you solve it?
« Last Edit: October 09, 2012, 05:31:58 AM by VirginiaJim »
Re: Radar detector won't stay plugged in.
« Reply #1 on: September 01, 2012, 10:55:48 AM »
Put a small piece of the fuzzy velcro on the plug, if you need more add another small piece on the other side.
« Reply #2 on: September 01, 2012, 11:29:41 AM »
Or plug the thing in and shove a wooden tooth pick in there to hold it.
« Reply #3 on: September 01, 2012, 11:39:55 AM »
+1...
« Reply #4 on: September 01, 2012, 11:43:38 AM »
Offline BackInTheSaddle
« Reply #5 on: September 01, 2012, 12:03:18 PM »
Had the same problem with my GPS until I hardwired it.  I thought it was just my bike as a defect, but it seems that the basic design is oversized.  I agree with the suggestions already made to "tighten" the fit into the socket.
Don, Apple Valley, MN
2008 C-14 ABS, AeroFlow Tall, Murph's risers with wedges, Buell pegs, Zumo 590, lowered pegs, Russell Day-Long
Previous bikes 2001 Kawi C10 (RIP), and 1981 Honda CB650
http://i879.photobucket.com/albums/ab353/DonaldHollinger/MOTO/Map_zpse09bb1e5
Offline JamminJere
« Reply #6 on: September 01, 2012, 12:10:30 PM »
a wrap or two of black electrical tape around the plug where there are no contacts...
....black toothpick..  ::)
JJ
Offline Steve Poff
« Reply #7 on: September 01, 2012, 04:46:48 PM »
Thanks, guys.  Don't want to hardwire it 'cause I use it in my car.  I'll do the tape thing.
Offline MikeERideWNC
« Reply #8 on: September 01, 2012, 07:49:08 PM »
OK... I will say it:
How will hardwiring it effect your car... It would work out better. Less crap to move around.
In fact I have my car hardwired, too.
The only issue I could see is if you are using the 8500 X50 Smart cord with your smart phone...
If you only have an 8500, then that is a mute point.
Anyways, this will get you going for 6.99.
http://www.ebay.com/itm/Escort-Passport-Radar-Power-Cord-Cable-Direct-Hard-Wire-/160354431302?pt=US_Radar_Laser_Detectors&hash=item2555de7146
The smart cord is a cool feature. You do need an 8500 X50 with Revision 3.6 installed.
« Reply #9 on: September 01, 2012, 08:51:15 PM »
A black toothpick, right? ;D
Good for an extra 2 hp...  ;)
« Reply #10 on: September 02, 2012, 04:46:32 PM »
Best way to do it for sure.
« Reply #11 on: September 03, 2012, 10:05:02 AM »
It is amasing how many post whores replied to this exact topic from the same poster on every ZG forum across the net.
If I would have seen this topic sooner on other forums, I would not have wasted the time and effort to give a viable option.
What a waste of time.
« Reply #12 on: September 03, 2012, 10:12:59 AM »
And yet, here you are.
Offline McJunkie
« Reply #13 on: September 03, 2012, 11:24:18 AM »
Added a Powerlet to the blank on the other side.
« Reply #14 on: September 03, 2012, 12:11:35 PM »
« Reply #15 on: September 03, 2012, 01:13:37 PM »
« Reply #16 on: September 04, 2012, 02:36:00 PM »
Have you tried wedging the plug in place with the stove knob key? It won't work but the bent key might take your mind off the radar detector entirely....
Seriously this is a common situation. Wrap something around the plug such as a couple of turns of electrical tape (not over the contacts though) and that should hold it in place. An even better way to go would be to wire the device into the bike using the acc. leads under the top / left fairing cover if that works for you.
« Reply #17 on: September 04, 2012, 02:51:47 PM »
Bet a Honda 12v receptacle  works better  ::)
Offline orangewingnut
« Reply #18 on: September 04, 2012, 03:25:11 PM »
i had the same problem and i also use mine in the car as well as on the bike. bought a direct power cord from escort. i grabbed power from the wires going to the accessory socket and the other end just plugs into the radar detector with  a plug that looks like those u use in a telephone jack. I just unplug it when im not using it and let the wire hang down. I have a redline and im thinkin the 8500 is similiar.
Bill
Offline ninjawarrior1400
« Reply #19 on: September 04, 2012, 03:29:06 PM »
Cut a short piece of paper from 3x5 index card, wrap maybe a full turn of paper around the plug and push it into place, do it a few times until you feel there is a strong effort required to push it into place so it won't fall out.
Simple no cost fix.
Ninjawarrior
