Make sure you take the two side panels off before removing the gas tank. Otherwise, you run a very high risk of scratching them up when the tank edges touch them. The tank is only held on by two bolts (plus the fuel line, vacuum line, and gas gauge wiring and drain tube cover). Don't loose the two black rubber grommets that the front of the gas tank rests on. They have a habit of falling and disappearing into the engine and front fairing area.
If you remove the seat and ther is a black plastic tray there and no visable battery, remove the two screws and two 10mm bolts, and it is below it.
