Author Topic: <yawn> Michelin does it again  (Read 3328 times)
« on: August 29, 2013, 01:20:05 PM »
Consumer Reports:  "Michelin dominates our latest tire Ratings"
Consumer Reports has just published the latest results of 49 tested models of ultra-high-performance (UHP) summer and all-season tires, and performance winter tires. The big winner? Michelin. But Goodyear, Nokian, Pirelli, and others have traction, too.
http://consumerreports.org/cro/news/2013/08/latest-tire-ratings-all-season-performance-winter-consumer-reports-news/index.htm
Offline sherob
Re: <yawn> Michelin does it again
« Reply #1 on: August 29, 2013, 01:58:35 PM »
What I put on my truck... wife's truck... LTX M/S 2's!
Rob
« Reply #2 on: August 29, 2013, 02:32:55 PM »
Are you saying that those are the tire we should be using on our C-14's?
« Reply #3 on: August 29, 2013, 02:43:12 PM »
Car tire thread!
« Reply #4 on: August 29, 2013, 02:44:28 PM »
No sir, topic was Michelin's success in the car arena.
hmmmm some here do ride C14 on car tires, for those I suggest none other
Offline sherob
« Reply #5 on: August 29, 2013, 02:50:18 PM »
Will you start a car oil thread, please.  ;D
Rob
« Reply #6 on: August 29, 2013, 02:54:11 PM »
Does Michelin require nitrogen in their tires?
« Reply #7 on: August 29, 2013, 05:46:38 PM »
I wish They would make a Jeep tire along the lines of the Goodyear MTR Kevlar.
« Reply #8 on: August 29, 2013, 08:44:30 PM »
Sure!  ;D ;D
Offline Mettler1
« Reply #9 on: August 29, 2013, 09:19:58 PM »
  Why nitrogen? Does it inflate tires better?
« Reply #10 on: August 30, 2013, 04:28:01 AM »
It starts with an 'N'.
Offline Cholla
« Reply #11 on: August 30, 2013, 08:32:46 AM »
I use the nitrogen blend in my tires.
Offline Cold Streak
« Reply #12 on: August 30, 2013, 12:42:48 PM »
Once you use Nitrogen, you can never go back to regular air again, or so I heard.   ;D
« Reply #13 on: August 30, 2013, 01:52:51 PM »
I suspect its alright if you mix the new air with a fresh mixture of snake oil and dyna beads  ;D
« Reply #14 on: August 30, 2013, 04:30:06 PM »
Michelin's sidewalls are thin, so the ride is smooth. Goodyear's sidewalls are stiff, giving better handling.
Choose your weapon.
