Author Topic: need a new horn  (Read 18721 times)
Offline 2talltim
  • 2008 C14
need a new horn
« on: September 07, 2013, 04:18:04 AM »
The silver bitch sounds like a dying duck so I want to replace the horn. And I'm not putting another oem squak box on it. When I had my TL I put a VW horn on it, it sounded okay but I want to hear options and opinions...go
Offline ljcorby
  • COG#: 9359
Re: need a new horn
« Reply #1 on: September 07, 2013, 05:53:58 AM »
I went with the Screaming Banshee horn.....there was a group buy quite a while ago and it was cost effective.  Very nice.
http://screaming-banshee.com/banshee-horn-warning-system
10 Kawi Concours 14 ABS
Re: need a new horn
« Reply #2 on: September 07, 2013, 06:26:27 AM »
No matter which aftermarket horn you go with keep in mind that the stock horn switch may not be able to handle the extra current draw. You'd be well advised to install a relay that's controlled by the horn switch and connected directly to the battery so that the stock switch doesn't go up in smoke.
Re: need a new horn
« Reply #3 on: September 07, 2013, 06:47:29 AM »
How about these horns?
Offline wingrider
Re: need a new horn
« Reply #4 on: September 07, 2013, 06:52:51 AM »
Nice horns but will she blow them?
Re: need a new horn
« Reply #5 on: September 07, 2013, 06:56:22 AM »
Good question.
Offline PH14
Re: need a new horn
« Reply #6 on: September 07, 2013, 08:42:03 AM »
I got these from Murph: http://www.murphskits.com/catalog/product_info.php?manufacturers_id=45&products_id=356&osCsid=38f94b825f87a8871b55d7abe52b455e
I love them. They are much louder. Much.
Re: need a new horn
« Reply #7 on: September 07, 2013, 08:55:57 AM »
PIAA sports horn Tim, trust me they are loud. And you need no relay, that is what I am going to buy soon. I heard one over the weekend, it was quite impressive.
Re: need a new horn
« Reply #8 on: September 07, 2013, 09:20:07 AM »
If you want a "real" horn, then install an air horn (and relay).  Search the forum for "Nautilus" and you will find many threads.  It is a lot more work and hard to find a good mounting place, but it blows away any electric horn.  Love mine.
http://www.zggtr.org/index.php?topic=286
http://www.zggtr.org/index.php?topic=3104
Re: need a new horn
« Reply #9 on: September 07, 2013, 10:36:57 AM »
The Wolo Bad Boy airhorn is always available if you have a walk in Harbor Freight near ya, dangerous place to have close to home.... credit cards get flattened fast there...heheh
Also seeen them at Advance autoparts, and Autozone, and PepBoys...right around $30... http://www.amazon.com/Wolo-Model-419-Bad-Horn/dp/B000F5DQWY
Re: need a new horn
« Reply #10 on: September 07, 2013, 12:00:48 PM »
Interesting.  That looks almost identical to the Stebel Nautilus we are all using...
Offline RBX QB
Re: need a new horn
« Reply #11 on: September 07, 2013, 12:18:55 PM »
They are the same. I've had the Wolo version on my Duc for years with no issues, so quality seems to be the same... just the benefit of saving a few bucks and possibly finding it on the shelf at Harbor Freight.
2011 Concours 14 ABS
Re: need a new horn
« Reply #12 on: September 07, 2013, 12:39:09 PM »
yes, they are completely identical, and I am sure that both are made by the exact same manufacturer.
I'm talking about the Nautilus compact...
I think the banshee is also made by the same company....
I'm pretty much sure all 3 can be modified to allow a split system for better fitment like this
Re: need a new horn
« Reply #13 on: September 07, 2013, 12:52:05 PM »
I can assure you Max that the PIAA sports horn is a "real horn", some of us don't want to have to deal with a relay and a large horn that is a pain in the ass to mount.
Re: need a new horn
« Reply #14 on: September 07, 2013, 01:01:09 PM »
I forgot to mention they come in a CHROMED version.... Bling.... 8) ;)
ooo I went to look at them, wow, they are easy to install, they say "no wiring is required"..
http://www.piaa.com/store/p/411-Powersports-Slim-Line-Sports-Horn-500Hz.aspx
anbody want my Wolo, I really didn't want to wire it in.... :rotflmao:
just kidding...
actually for the money you can't beat the Fiamms...
http://www.amazon.com/FIAMM-72112-Freeway-Blaster-Horn/dp/B000DINKPQ/ref=pd_sim_auto_11
I know how frugal you are Poke... ;)
I have heard these, with the high and low pair mounted, and they are DAMNED loud. ???
Offline Jay
  • 1979 Kawasaki KZ1000ST
Re: need a new horn
« Reply #15 on: September 07, 2013, 02:10:27 PM »
That's what I installed (the high and low pair mounted) and it is pretty damn loud.
Attached them to the OEM horn mount with two 3" metal extensions.
A bit tight down there but with the correct angles they don't hit the fender when going into driveways.
Does require a relay, though. Put mine under the plastic cover over the gas tank.
- 2011 Kawasaki Concours 14, Black
- 1979 Kawasaki KZ1000ST (Shaft Drive)
- 1976 Triumph Bonneville 750
Offline Jay
Re: need a new horn
« Reply #16 on: September 07, 2013, 02:22:15 PM »
My FIAMM 72112 Freeway Blaster Horns where a bit of a PITA to install.
If I knew about the PIAA sports horn, I would have probably gone with that.  :(
Powersports Slim Line Sports Horn (500Hz) $64.50 +shipping
http://www.piaa.com/store/p/411-Powersports-Slim-Line-Sports-Horn-500Hz.aspx#
PIAA 76501 500Hz Slim Line Sports Horn  $47.25 +Free Shipping
Re: need a new horn
« Reply #17 on: September 07, 2013, 02:29:48 PM »
It really is a pain in the ass to mount.  Still think it is worth it, though :)
Re: need a new horn
« Reply #18 on: September 07, 2013, 02:57:42 PM »
They are nasty loud for sure, sounds like a locomotive!  :thumbs:
Offline clogan
Re: need a new horn
« Reply #19 on: September 07, 2013, 06:35:54 PM »
I've had a Wolo on each of my last four bikes...i'll have one on my next bike too.
2010 Neptune blue C14
2009 blue KLR
2013 DRZ400
