Author Topic: Throttle Lock for C10 Connie  (Read 6791 times)
Offline Mort Canard
« on: April 19, 2017, 06:21:56 AM »
Have been wanting a throttle lock for a C10.  Most of the ones I have seen use a forked tab that slots over a throttle cable.  The problem is the Connie does not have a throttle cable where the throttle lock depends on having one.
What are the Throttle Locks you have found that work?  I would like to get one installed so I can give my right hand a rest from the Connie bar buzz every now and then.
Little wheel turns by the fire and the rod.
Big wheel turns by the grace of god.
Every time that wheel comes round,
'Bound to cover just a little more ground.
Offline Jim __
Re: Throttle Lock for C10 Connie
« Reply #1 on: April 19, 2017, 06:48:49 AM »
I purchased my bike with the heavy Throttlemeister lock already installed.  Very well made and the extra weight is supposed to help squelch some of the vibration.  Once set, the operation is very smooth.  However, besides being very expensive, there is no simple way to engage/disengage with your right hand.  I usually reach over and set/release it with my left hand to avoid chopping the throttle.  I had the plain-jane Vista Cruise that you mentioned on my previous bike.  It was so much easier to use.  If your concerned about making the Vista Cruise work your bike, do a Google.com search for "vista cruise mod for kawasaki".  Plenty of ideas to make it work just fine.
Offline DON B
« Reply #2 on: April 19, 2017, 08:40:15 AM »
What you need is Omni-Cruze.Fits nice, works well. At  Omni- Cruze.com
« Reply #3 on: April 19, 2017, 08:41:29 AM »
+1 on the Omni
Offline DON B
« Reply #4 on: April 19, 2017, 08:43:01 AM »
Oops, misspelled, Omni- Cruise.
Offline Mort Canard
« Reply #5 on: April 20, 2017, 06:19:18 PM »
Thanks for the ideas folks.  Looks like some good options.
Offline George R. Young
  • Moderator
    • Concours 2001 Farkles
« Reply #6 on: April 20, 2017, 08:48:11 PM »
Offline Mort Canard
« Reply #7 on: April 24, 2017, 11:44:24 AM »
Offline timsatx
« Reply #8 on: July 29, 2017, 10:00:27 PM »
What I did was use a barrel nut. Using a Vista Cruise I cut off the part that goes over the cable. Establish the angle that you want to use and mark it on the throttle housing. Drill a hole to run the screw thru to the nut. Don't make it too close though as it will bind the throttle. That's why you don't use a regular screw and nut. I got it at Lowes I believe. It looks like the picture below.
Offline Mort Canard
« Reply #9 on: July 30, 2017, 05:51:39 AM »
Timsatx,
Your pictures are not showing due to photobuckets ban on third party hosting unless you pay $400 per year.  You're probably going to have to replace your image hosting site.
Offline timsatx
« Reply #10 on: July 30, 2017, 06:40:21 AM »
I'll check in to that. Last night the photos were showing.
« Reply #11 on: July 30, 2017, 06:58:05 AM »
Yeah, you have been 'photobucketed'. Let's make it a verb, hell, we are all suffering from being 'photobucketed'.
Kinda' like being 'disappeared' in Argentina.  :(  Given these admittedly few examples, it would seem pretty negative when we hack a noun into a verb in English....
Imgur seems to be working for me. A free site (no idea for how long though) and it is easy to use.
I am not a spokesman for them, just passing along what I have found in my own recent trials after being 'photobucketed' myself.
Offline timsatx
« Reply #12 on: August 02, 2017, 10:28:12 PM »
Did you try scrolling down when doing a reply. I just did that and the pics showed up. Still working on new space.
Offline Mort Canard
« Reply #13 on: August 07, 2017, 01:02:35 PM »
Those pics are working.  Still can't see the original ones.
Thanks for the idea!
Offline timsatx
« Reply #14 on: August 07, 2017, 07:37:32 PM »
Yeah, thank you chronicler.
