Author Topic: New bike, need some advice/help on some basic things  (Read 1657 times)
Offline robertv
  • 2008 C14 Silver
Re: New bike, need some advice/help on some basic things
« Reply #15 on: June 26, 2019, 02:45:41 pm »
« Reply #16 on: June 26, 2019, 03:45:45 pm »
Do i plug them together, or cap em off once I've removed the gps?
no, no, no.....
 that is a silly question, but NO...
just unplug the 2 connections, and leave them lay, or wrap them in tape if you wish...  think about it... you have 2 12v wires there, one is Pos+ one is Neg-.... pluging them together is like connecting a wire between both posts on a battery.. you will burn the bike down.
I really hope you read this before you even do what you were thinking, .. and, I can't fathom thinking that at all anyways.. but... people with out .... do .. odd things....
And, if you did connect them together, and nothing "happened"... and thought, "ok, cool"...(which with the bike Off, would be normal)  and then, turn the bike on, and hit the start switch, energizing that circuit....  "Puffff"" and the "magic smoke" is released from the wire...
30 YEARS OF KAW.....
Offline Jgiacobbe
« Reply #17 on: June 26, 2019, 04:26:33 pm »
Gas tank ring is for a Givi tanklock bag. I have one on my other bikes and just installed it on my C14. My C14 is fairly new to me and I have not had it long. Just installed R&G bars. My bike was ex-police and already had the MC enterprises bars on the rear but the front ones had been removed.
Offline dxr
« Reply #18 on: June 26, 2019, 06:49:11 pm »
no, no, no.....
Every machine is a smoke machine if you operate it wrong enough!
Offline Michelle
  • Saving the chubby unicorns
« Reply #19 on: June 26, 2019, 07:48:59 pm »
The positive wire is the one with the plastic shroud over it - so it can't touch anything and the bare one is an earth. It comes from the factory with them dangling like that, just hidden inside the big rubber boot.
There is also another pair just like them under the rear seat, near the ECU.
Its OK MOB. He says he is only researching at this stage. He won't do anything silly until August.  ;)
Offline MtnRider
« Reply #20 on: June 26, 2019, 08:03:15 pm »
But, OH MY! The farkle silliness that can ensue at that point...
Nope! I'm not guilty at all.....     :o ;D
Offline dxr
« Reply #21 on: June 29, 2019, 11:22:39 am »
5) Whats the best option for fairing protection?  (crash bars/sliders/etc?)
https://www.rg-racing.com/browsebike/Kawasaki/GTR1400_Concours/2016/AB0002BK/
I just got these installed on my 16 model.
How well do the full bars/cages work vs frame sliders?
« Reply #22 on: June 29, 2019, 02:51:52 pm »
Much better, from my understanding.  Sliders don't offer the coverage, have little ability to absorb energy, and can't spread the load because all the impact goes to single point.  Of course, they are also less obstructive, far less expensive, easier to install, and don't interfere with maintenance.
I have yet to see any evidence that, on the Concours, any type/brand/model of sliders will prevent fall-over damage.  Yet, there is plenty for the Canyon Cages (both video and testimonials, plus my own experience).   But I have also not seen any evidence for any OTHER brand of cages/bars, other than a little on the Top Blocks.
Offline katata1100
« Reply #23 on: June 29, 2019, 10:44:14 pm »
Remove the black plastic trim that has the glove box, remove and replace the air filter . It’s not much bigger than the one in my lawn mower and there’s a good chance it’s full of crud.
After that, replace the missing screw that goes at the bottom of glove box as your reinstall that trim piece.
Offline dxr
« Reply #24 on: July 02, 2019, 10:35:28 pm »
Next questions:
LED headlight bulbs-is there any consensus for what kit is best?
Backup keys, what's the easiest way to make a spare key for opening saddlebags? Can blanks be easily acquired somewhere?
Brakes:. The linked Brake system seems to have a slight jerk to it as it kicks in, is this normal?
Windscreen: with it all the way up, 3/4s of my head is still right in the wind.  I have to slouch down n duck my head almost 6"to get out of the turbulence... What's a better solution, a clip on windshield extension vs a replacement aftermarket screen?
Battery: i suspect my battery is getting old, cold cranking sometimes takes more than a second or 2 to kick over.  Is there a preference around here for replacement?
Throttle:. I'm still learning the feel of it, but it feels real on/off in the lower rev range, where barely and input at the wrist results in quick acceleration.(look I used to have a Harley I'm not used to having actually power, lol). Some posts indicated getting the ECU flashed can change how it responds, where's a good start to researching this?
Offline Michelle
« Reply #25 on: July 03, 2019, 01:57:28 am »
I covered LED previously. I think you should just buy one and try it. Not everyone likes them, but they are all very similar. Apart from colour temperature. Personally, I don't see real good in the blue end of the spectrum, so I try to use ones 6000k or less.
Backup keys can be done at most key cutting places if they have the blank. They come in left and right handed blades and it depends whether your particular machine has an A or B key. My spare is cut from a Yamaha blank.
I can't tell you whether the linked brakes are normal because my bike only recently got them and I'm not sure if I like it or not.
Batteries are another personal preference thing. I just stick with the one in the book.
Ah, the old on/off throttle trick! When I first got mine I thought it was just the way I rode it. A Shoodaben flash fixed that. I think the series 2 bike is a bit more civilised with the throttle, but if you're looking to fix it then Steve Sefsick is your man. You could research it, but unless you're looking for a cheap hack you will find yourself at Shoodaben Engineering.
« Reply #26 on: July 03, 2019, 05:49:10 am »
Next questions: LED headlight bulbs-is there any consensus for what kit is best?
Too many to know, and they change constantly.... so any recommendation would be meaningless.
Lots of threads on that
No.  The linking is variable and smooth.  You are noticing something else.  What, I don't know- unless you are braking very hard and you might be noticing ABS.
http://www.zggtr.org/index.php?topic=16222.0
There are a zillion threads on batteries, some from just the last month.
Lots of threads.  Look at Shoodaben Mountain Runner.  And if you then don't think that flashing is enough (which you really HAVE to do if you want the bike to be what it needs to be) then Throttle Tamer.
Offline kzz1king
« Reply #27 on: July 03, 2019, 11:15:35 am »
Adjusting any slack out of the throttle can also improve things.
2010 CONCOURS
1974 Z-1
« Reply #28 on: July 03, 2019, 03:33:22 pm »
+1.  Seems to need adjustment within the first year then, for me, about once every 2 to 3 years.
« Reply #29 on: July 03, 2019, 04:44:57 pm »
I did mine the same day I brought it home.. have'nt touched it since, i could tell in the first 5 minutes of riding the beast, it needed it..
Now... must shut of computer... and get my lazy azzzz 10 feet, and install my "Mountain Runner Premium" flashed ECU...
man, I'm getting sooooo lazy. :'(
