Author Topic: 2004 model 4-pot brake upgrade  (Read 10890 times)
Offline Centex
    • Central Motorcycle Roadracing Association
« on: July 29, 2011, 05:46:36 PM »
First, thanks to Gary in CA for sharing his brake upgrade experience, thanks to Slybones for sharing his experience through his excellent website of Connie information, and thanks to COGger zrxmopar (Shaun) for his original 4-pot brake brackets which, based on Slybones' brake upgrade webpage, I’ve probably copied.
My bike is an '04 model.  The calipers are 4-pot Suzuki GSXR 750, 2001 to 2003 model, fresh seal kit installed.  The rotors are EBC 320mm Contour.  The pads are EBC HH.  The Galfer brake lines have been on my bike for years with the OEM calipers, not changed for this upgrade.
I started by making a full-size prototype out of Plexiglas sheet to get the locations for the holes and the shape to fit the calipers.  It took 2 trials to get the calipers perfectly aligned for the pads to track correctly on the 320mm rotors.  The prototype proved that the flat plate centers the caliper perfectly on the rotor when used on the inside face of the caliper lugs.  The bracket is tapped for the 4 bolts, the threads in the caliper lugs are drilled out to pass the M8x1.25x16 flange head bolts.  No other modification to the calipers at all.  The OEM C10 brake bolts are used at the fork leg.
The pics tell the story … the brackets are 3/16” steel plate.  Holes were done with a benchtop drill press through the Plexiglas template and hand-tapped.  I was not able to get time on a mill as I’d hoped when I started this project, so finally I just carved the brackets using abrasive cutoff and grinding disks on a 4.5 in Bosch angle grinder – very easy and quick.  A few licks with a file to round the sharp edges and a couple of coats of rattle-can caliper paint on the brackets to finish.
View of the bracket from the wheel-side shows the basic shape
Close-up from the outside; flange head bolts through the calipers are zinc plate, class 10.9
Looks like I'll have to watch that speedo cable to ensure it doesn't hang on the corner of the caliper
Alan in Central Texas
2004 Connie COG 9476
2001 Ducati M750
Re: 2004 model 4-pot brake upgrade
« Reply #1 on: July 29, 2011, 05:56:18 PM »
Very clever and "clear" idea to use the plexiglas to make your prototypes..... Looking good!
Offline Centex
« Reply #2 on: July 29, 2011, 06:00:00 PM »
Plexiglas drills and taps easy, allowing a full bolt-up fit and alignment test.
2001 Ducati M750
Offline Cavediver
« Reply #3 on: July 29, 2011, 06:28:17 PM »
Very nice This might be my next project.
Jack
Offline throb
« Reply #4 on: July 30, 2011, 04:06:50 AM »
How much better is the braking with these calipers?
Offline Daytona_Mike
« Reply #5 on: July 30, 2011, 08:15:13 AM »
The braking improves by a factor of  :pukeface: 'Blah!' to 'WOW! :thumbs:
 It is not just the calipers, it is the calipers and going from 300mm to 320mm.
Offline throb
« Reply #6 on: July 31, 2011, 04:50:53 AM »
Sweet, is there anyone making the adapter plates yet or is this a figure it out yourself deal?
Offline jim snyder
« Reply #7 on: July 31, 2011, 11:39:32 AM »
We are still working on it.
Offline Cybercraig
    • Sprayboy-Services
« Reply #8 on: July 31, 2011, 11:55:16 AM »
4 pot calipers? 320mm discs? It doesn't get any better than this! Nice job!  :thumbs:
'98 becoming more farkled up by the minute.
R.I.P. Steve Earl  "Mr. FJR"
Offline ATC Buckeye
« Reply #9 on: August 01, 2011, 06:14:02 AM »
I want these plates in the worst way.
enim57
« Reply #10 on: August 02, 2011, 02:47:43 AM »
It's about time someone made a neat & simple bracket for this. Very similar to the ones I make for the 86-93 models. Well done!
Regards, Russell
Offline sas mayhem
« Reply #11 on: August 02, 2011, 02:59:30 AM »
09 Connie
Offline throb
« Reply #12 on: August 02, 2011, 03:19:01 AM »
I'm certain you can sell a ton of them...in fact, if there's a waiting list, put me on it!   :P    ;)
Offline kzz1king
« Reply #13 on: August 02, 2011, 07:22:35 PM »
So I am looking for info on the 4 pot mod to the older Connies. Cost? Parts needed? Thanks
2010 CONCOURS
1974 Z-1
Offline 2fast
  • COG #6497, North Central Area Director
    • C-10 Heat Shield photos
« Reply #14 on: August 02, 2011, 08:26:55 PM »
Here's what I did. http://forum.cog-online.org/index.php/topic,28138.0.html You can see em in Vermont in a few days if you are going.
Brian in Minnesota
Need Heat Shields for the C-10? 86-93 Front Brake upgrade brackets?  I got em! Click the little green globe under my Avatar on the left.
Offline jim snyder
« Reply #15 on: August 02, 2011, 09:18:49 PM »
Very nice 2F. Where did you get the rotors and what brand are they? I am fixing to fabricate some of these brackets very soon, as soon as the temperature gets below 100 here in Texas, which should be about november.
Offline 2fast
« Reply #16 on: August 03, 2011, 07:52:07 AM »
Jim,
The rotors are Chinese from these guys http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=310261175803#ht_1077wt_681 and are made for a Yamaha YZF R7. They fit the older model center hole, but the mounting holes need to be drilled out one size.  I don't have many miles on them yet, but by the time I get back from Vermont they will be fully tested.
Brian in Minnesota
Offline jim snyder
« Reply #17 on: August 03, 2011, 10:25:38 AM »
Jim,
So they will only fit the older model front wheel ?
Offline 2fast
« Reply #18 on: August 03, 2011, 03:38:29 PM »
Brian in Minnesota
Offline Centex
« Reply #19 on: August 03, 2011, 04:01:29 PM »
Brian / Jim - I notice that the rotors you linked above are replacement for the 94-06 Connie, so they are 300mm, not 320mm.
If you want 320mm for exact fit on the 94-06 Connie, look for replacements for the following bikes (among others) which came with 320mm stock and the correct bolt pattern / offset:
93-01 ZX11
00-03 ZX12
2001 Ducati M750
