Author Topic: A thread about nothing at all....  (Read 525263 times)
Re: A thread about nothing at all....
« Reply #1380 on: March 09, 2014, 06:31:32 am »
I wonder when the first post asking how to set the clock on a C-14 will show up?  ;)
« Reply #1381 on: March 09, 2014, 07:20:48 am »
Mine's been off since I put a new battery in 2 years ago. A clock on a bike is as wrong as a radio or telephone.
« Reply #1382 on: March 09, 2014, 07:28:58 am »
You're right there G. I used to use my bike's clock to see how late I was for work. I won't be needing that info any longer...    :)
« Reply #1383 on: March 09, 2014, 07:40:36 am »
:thumbs:
« Reply #1384 on: March 09, 2014, 09:34:26 am »
Through some sort of miracle, my clock is now correct..
« Reply #1385 on: March 09, 2014, 10:05:15 am »
Even a stopped clock is right twice a day.
« Reply #1386 on: March 09, 2014, 12:07:32 pm »
I can beat that, mine is right for about half a year or so, as is my electric IBM time clock I picked up in a flea market last year.
« Last Edit: March 09, 2014, 05:08:58 pm by VirginiaJim »
« Reply #1387 on: March 09, 2014, 05:15:00 pm »
A funny thing happened on the way from the bedroom upstairs to the kitchen downstairs this morning.  Smelled something burning....wood burning to be exact.  Nothing was on, no smoke.  Fire alarms had not activated, so where was it coming from?  On a hunch I opened the dishwasher.   I put some dishes in last night and figured I check that out.  The smell was coming from inside the dishwasher!  I found the culprit, a wooden spatula that was turned into charcoal on the wooden handle end and the rubber end had a scorch mark as well.  Seems it fell from the top rack, through the bottom rack and landed on the heater element.  The perfect storm so to speak.
Unfortunately, I can't get the smell out of the dishwasher.  Any hints?
« Reply #1388 on: March 09, 2014, 05:37:08 pm »
start with this many cycles:  http://www.repairclinic.com/PartDetail/Dishwasher-Cleaner/W10282479/1552531
then FYI the more you USE the dishwasher, the less the smell will be there
« Reply #1389 on: March 09, 2014, 06:11:23 pm »
Well, do you have a wood stove now? Do you want one? If so, consider putting a smokestack in the dishwasher and a small draft hole in the front- viola! The buy a new, non- stenchified dish washer (sans smoke stack and draft hole) and poof- everybody is happy!
Or you could take the coward's way out and do what Steve said: just keep doing dishes in it.
One other thing you might try: when shaving brushes are brand new, they can be quite odorific and it ain't a pleasant odor (both boar and badger brushes can be pretty funky)- the preferred way to de- funk them is by using Oxiclean powder. You could try that in the dishwasher- soak everything inside it with Oxiclean and let is soak for a few minutes then cycle the machine and see if the stench calms down.
« Reply #1390 on: March 09, 2014, 06:15:23 pm »
uhmmm steve said clean it first with the real purpose cleaner in link provided, then separately FYI'd (no matter what, using/cycling it will diminish the smell).
edit:  I like your Billy Mays oxiclean solution you offer too. I didn't realize people select that cleaner  ;D
« Reply #1391 on: March 10, 2014, 04:42:55 am »
Yeah, leave the door closed. I'm sure that the dirty dishes won't mind the smell.
« Reply #1392 on: March 10, 2014, 05:27:58 am »
Unfortunately, the smell comes out of the upper vent in the door.  It's diminished this morning but still there.
Steve, thanks for that link.  I didn't know that Affresh made something for the dishwasher.  I use their cleaners for the front loading washing machine for the last several years.
« Reply #1393 on: March 13, 2014, 02:44:23 pm »
« Reply #1394 on: March 13, 2014, 02:48:37 pm »
Odor check: how are the olfactory glands doing at your house Jim?
