Author Topic: $260 90 Concours Resurection New Member to ZG/ GTR Fanatics  (Read 18007 times)
Offline DonB
  • Let's Ride
Re: $260 90 Concours Resurection New Member to ZG/ GTR Fanatics
« Reply #20 on: November 08, 2011, 09:08:05 PM »
an FJR buddy and I are going to ride from the springs hwy 83 to Castle rock for lunch on Thur
2012 Candy Arabian Red C14 but it's not Red to me
2012 Blue ABS Wing
2011 White Vstrom                               = o&o>
Offline Motor Head
  • Resurected Concours, $260 Purchase & Counting
« Reply #21 on: November 08, 2011, 09:10:49 PM »
I can't I got to do the DIA taxi service on Thursday.  ::)
But it sounds like the best weather according to the Guessers.
1990 ZG1000 C10
1982 KZ1000 LTD
Offline CRocker
« Reply #22 on: November 08, 2011, 09:20:04 PM »
Where you planning on stopping for lunch?
'02 C-10
Offline DonB
  • Let's Ride
« Reply #23 on: November 08, 2011, 09:23:04 PM »
Santiago's Mexican joint
2012 Blue ABS Wing
Offline CRocker
« Reply #24 on: November 08, 2011, 09:24:47 PM »
Been to "Crave Real Burgers"?
'02 C-10
Offline DonB
  • Let's Ride
« Reply #25 on: November 08, 2011, 09:26:23 PM »
don't think I have been there
2012 Blue ABS Wing
Offline CRocker
'02 C-10
Offline Connie Mark
« Reply #27 on: November 08, 2011, 11:05:17 PM »
Connie Mark,
Where do you want to Ride tomorrow, and what time? The Connie won't ride, but the KZ1000, just needs a bit O gas!
I sadly have to go into work at around 9:30 in the a.m. That pretty well kills the morning. Probably done around 11:00. I do have plans for lunch at 1:30, so I may have spoken too soon. I will try to turn those lunch plans into dinner plans. My # is (3), 834, three sevens and a 2. Let's talk around 9:00 am if that works for you.
Offline Motor Head
« Reply #28 on: November 15, 2011, 08:36:46 PM »
 So yesterday Monday the 14th a couple of us meet up and did a couple hundred miles  out in the Flats, 6K' in the Wind. All in all pretty decent day, with a bit of cruising at 80 or so.
 Checked the mileage of my first fill up, ride I did by myself a week or so ago. 46mpg on that ride which was up to 10K', and while I hadn't done the brake upgrade yet, so i didn't go into the corners real fast. I did run it a bit though, 80+ @ over 9K'.
 So I'll get another fill up after this last ride in a day or two. Hopefully taller windshield tomorrow afternoon, Wednesday.
 Pulled the Timing Rotor after checking the Factory setting, and increased it to the extra 4 degrees, so now 14-39 curve. While I was there i pulled the T-chain tensioner for a look see, all good so I just re-set it and re-installed.
 Then 1 of the shift linkage Ball Joints was getting loose, so i got a couple of new Heim Joints and a bit of hardware to redo the linkage. Nice and tight now-$8. Popped on a Vista Cruise Thumb Lock as well for the straights. I have one on the KZ and really like it.
 Have to have another ride at least before any other changes to the tuning.
« Last Edit: November 15, 2011, 09:26:15 PM by Motor Head »
1990 ZG1000 C10
1982 KZ1000 LTD
Offline Motor Head
« Reply #29 on: November 17, 2011, 06:15:21 PM »
 Decided to do the Overflow tubes Today, as it was easy and cheap. Like $4 for enough Brass Tube to do 5 sets of carbs. It is really easy for those who believe they are capable. There is a good write up here: http://web.ncf.ca/ag136/floatDrainTubes.htm by one of the members here.
 I also set up the Float Bowls with different hardware, long Socket Head Cap Screws, 40mm, with a lock-nut/ washer that works like the Head of the Original screw. So once loosened the head works as a thumb wheel. So the bowls come off a lot easier if needed.
 The 25" Clear View windshield I bought off of a member here showed up Today in the Mail, it's mounted but I will give it a ride tomorrow. Hopefully it will be better than the Stocker for wind around buffeting and noise around the Helmet. The Buffeting at 80+ was great from the stock shield. I'm over 6'.
1990 ZG1000 C10
1982 KZ1000 LTD
« Reply #30 on: November 18, 2011, 04:42:35 AM »
Interesting idea with the long screws; I like.
Offline kzz1king
« Reply #31 on: November 18, 2011, 05:45:40 AM »
With the long screws do you locktite or jam the nuts? Or snug them with a wrench?
Wayne
2010 CONCOURS
1974 Z-1
Offline Motor Head
« Reply #32 on: November 18, 2011, 06:47:12 AM »
T Cro ®,
There are purpose made long thumb wheel bowl screws, as well as a long thumb wheel Idle Mixture screw. I needed a few screws as the Phillips head was damaged. So off to Fastenal for some different replacements. Pretty cheap, and much easier too pull the bowls on the bike.
kzz1king,
They are Ny-lock nuts. They go on BACKWARDS all the way down the threaded section, then the washer, screw in normally. So the nut is just the Head of the screw. But it is a Dummy, just there to still apply the pressure against the Bowl. The socket cap screw is where you do the actual tightening, and twisting with your thumb/ forefinger.
4mm x .7 pitch 40mm long 16 needed/ Ny-Locks/Washers. About $4
This clears the Idle Adjustment speed thumb wheel, Just.
1990 ZG1000 C10
1982 KZ1000 LTD
« Reply #33 on: November 18, 2011, 11:49:42 AM »
T Cro ®,
Yep I looked at you pix on my iPhone this morning and liked it; looked at it again on the computer and still like it...... I can see where the long screws/w locknut's could/would be used like thumb screws allowing you to remove the bowls with a lot less trouble. I've done this twice; once to install different main jets (I run a DJ kit) and once to clean the idle jets. While it requires nimble fingers and a cold engine it can be done as long as you've got hex head screws (allen head) not phillips.
Offline Motor Head
« Reply #34 on: November 23, 2011, 04:03:15 PM »
 Well the Volt Meter I ordered showed up the other day, and I got around to fitting it. Since I had replace my gauge cluster, because of broken plastic when I got the bike. I had a Spare Clock/ housing. This area I cut from the broken Gauge surround, then fitting it to the shape of the Top of trim panel, I glued it on to it. Cutting and filing on the Clock Insert area, I was able to fit the Digital Panel Volt Meter in the same area. So here is a few shots of the Dash, without the additional Gauge, the Dash was Off on 1 side. Only the Clock, on the Right. looks a bit strange like it needed something on the Left. Oh and I get a 13.8- 14V while riding.
1990 ZG1000 C10
1982 KZ1000 LTD
Offline SteveJ.
« Reply #35 on: November 23, 2011, 04:25:07 PM »
Nice install :thumbs:
America's Seaplane City
Offline Motor Head
« Reply #36 on: November 23, 2011, 04:35:12 PM »
 Thanks SteveJ.
 Its real easy to read, except with the sun on it. Just raise your left hand for a shade, then you can see it. Otherwise it is real big and Bright.  Sample Rate is like 5x a second.
1990 ZG1000 C10
1982 KZ1000 LTD
Offline Jet86
  • California
« Reply #37 on: November 23, 2011, 05:51:01 PM »
Hey that's nice, it actually looks like it belongs there, i to think the clock makes it look weird but with them both on there it just looks right.
« Reply #38 on: November 24, 2011, 09:22:15 AM »
Nice installation.   8)
Offline Motor Head
« Reply #39 on: November 24, 2011, 05:28:06 PM »
 Thanks, connie_rider.
 Well it was just to nice here today to be indoors.
 So here is where I went, had the Sheriff in Victor tell me I was going to fast. At least it was a warning, Happy Thanksgiving to me. Couldn't believe all the bikes on the 105, 70 easy!! No other bikes up high though. There was a few patches of ice in the shade, in the middle of the road, Ok where the Caggers tires travel.
 About 300mi by the time I was done.
 8)
http://maps.google.com/maps?saddr=Colorado+Springs,+CO+80918&daddr=38.837444,-104.7944262+to:38.82487,-104.80422+to:Ca%C3%B1on+City,+CO+to:Cripple+Creek,+CO+to:38.71027,-105.1452+to:Woodland+Park,+CO+to:Deckers,+CO+to:Pine+Junction,+CO+to:39.503792,-105.1894628+to:Chatfield+Lake,+CO+to:Palmer+Lake,+CO+to:39.10005,-104.774035+to:Colorado+Springs,+CO+80918&hl=en&ie=UTF8&sll=38.556757,-105.250397&sspn=0.628226,1.234589&geocode=FSmiUQIdjm7B-SnPUuF0304ThzHC2cjxI6ooaw%3BFcScUAIdxvbA-SkX8XuVqEUThzEO4ymEZ90xKw%3BFaZrUAIdhNDA-SnbORZ6_kQThzFRLvhJlS66hA%3BFQ2MSgIdj2C6-SlncOmpkYUUhzHgc98OR2YmaQ%3BFR86TwIdNRu7-SlNzMF7haQUhzEDxiUnbcNK0Q%3BFf6rTgIdkJy7-Sk7LWmNyKMUhzHfgd4LsxClsQ%3BFdn_UgIdXvW8-SlBvg3Fy6oUhzFvYb-VdC4fzQ%3BFbj6VgIdRl26-SkX5E87-l1rhzHgQczcaJXAiQ%3BFXw2WgIdicy3-SF0XfT9gw_ihCm5kRgAxnJrhzEQ63pgL4YZmg%3BFbDHWgIdqu-6-Sm_O6HA9nprhzGS9lD0Q175Bw%3BFW50WwId7sC8-SlRlsqEuX1rhzHH48aJ1Q5mgg%3BFSb1VAIdLBe_-SnpzUpEz65shzEtSYCuicRecw%3BFZKeVAIdbUbB-SlDepF36rNshzEgfSAzLgZopA%3BFSmiUQIdjm7B-SnPUuF0304ThzHC2cjxI6ooaw&vpsrc=0&mra=dpe&mrsp=5&sz=10&via=1,2,5,9,12&t=m&z=10
1990 ZG1000 C10
1982 KZ1000 LTD
