Author Topic: 1109 buildup pix - a blast from the past!  (Read 3080 times)
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« on: November 07, 2011, 07:26:23 am »
http://rides.webshots.com/photo/2727133350078086933TxSIIt
  Here's some pix of my original 1109 top end buildup that I just happened to find. The cylinder block is a zx11 block with the cam chain channel cut off and the connie zg1000 channel welded on, then it was de-jugged, decked top and bottom, re-jugged, and bored +2mm for 1109 cc's. It's +4mm over a zg1000 bore. The head work is high velocity ported, with the ports filled with epoxy to raise and narrow the ports for midrange. A subsequent dyno run with the first 2 minute mod jetting netter 117 RWHP @ 9300 rpm. Enjoy! Steve
Offline SteveJ.
  • Mid Flowriduh a.a.d.
Re: 1109 buildup pix - a blast from the past!
« Reply #1 on: November 07, 2011, 12:18:17 pm »
This should give some folks a bit of perspective.  :thumbs:
'99 Conk: 227k mi, '98 KLR650 back from Cal
COG 5603, IBA 19921, CBMMA 50 (Cheap B@st@rds Motorcycle Maintenance Assoc, 14 year member)
Offline 2fast
  • COG #6497, North Central Area Director
    • C-10 Heat Shield photos
« Reply #2 on: November 26, 2011, 07:48:59 pm »
Got any photos of the chain case weldup? I think that is one of the more interesting things that most guys would not consider doing to make this work. Part of your mad scientist personality :hail:
Brian in Minnesota
Need Heat Shields for the C-10? 86-93 Front Brake upgrade brackets?  I got em! Click the little green globe under my Avatar on the left.
« Reply #3 on: November 26, 2011, 08:19:52 pm »
Offline vinny
« Reply #4 on: November 27, 2011, 05:14:58 am »
Awesome album Steve!
The welding is outstanding!
What is the benefit of the springless carbs?
« Reply #5 on: November 27, 2011, 07:11:53 am »
  It's using metered air to control the slides as opposed to using a spring. That way I can more easily make changes to the slide reaction, thus making carbs that are much more responsive and balanced, one to another. Steve
