Author Topic: High Altitude Jetting--5000' (1,500m+) and above  (Read 17131 times)
Offline AZBiker
    • My photos
« on: November 11, 2011, 11:24:34 PM »
So what's everybody running?  I live at 5,000', but the good roads by my house go up to 7,000'.
My current jetting is 135/38.  Bike is currently equipped with Cali emissions gear but will soon be stripped to 49-state form.
Stock airbox with K&N and stock exhaust.
Bike has never returned more than 30mpg, even on the highway.  I forget what the CO & HC readings were but it barely passed even after having the carbs synchronized.
FM says I can go down to 122/35 because of the altitude.
Prescott, AZ does not have a local dyno shop AFAIK and I'm not going to throw that kind of money at this bike anyway.  I just want to maximize my mileage.  HP is a non-issue, even the way it ran before it had enough power to get me in trouble.
I don't lug the motor either, fwiw.
rubber side down,
Derek
93 Cali black & red
Offline Rick Hall
  • Eruption
Re: High Altitude Jetting--5000' (1,500m+) and above
« Reply #1 on: November 11, 2011, 11:43:15 PM »
Stock airbox with K&N and stock exhaust. ...
Bought my '94 as a Cali model from a dealer in N. Phoenix. Been living in CO at 7400' for the last 13 years. Same basic setup as yours? Haven't touched the jets, run a K&N, stock emissions stuff, pilot screws dinked with many moons ago, ... I average around 38MPG, got 50+ MPG a few years ago, but I was escorting a Moped around the mountains at the time.
I wonder... has the fuel height in the bowls been checked? Got good spark? No air leaks?
Oh, are carbs are constant velocity, changes in altitude doesn't effect them that much. It's not *absolutely* necessary to change jets @ altitude, but a few do. I'm not one of them.
Rick
Offline AZBiker
    • My photos
« Reply #2 on: November 12, 2011, 02:05:42 AM »
Rick
Airbox boots are new, as are the boot spring clamp things.  When I reassemble the carbs I'm going to check the static float height first and then the fuel level and make sure it's dead on.  I even bought the "most expensive plastic tube ever" from Kaw to make sure I get it right.   The spark plugs all look fine and the plug wires have been replaced with new ones from Murph's.
I'm sick and tired of pulling the carbs.  This is the last time I pull them.  If it's not right this time, I'll probably sell the bike and quit riding until I can afford something with FI.  I've already replaced both of the air cut valves (outer one was ripped) and the fuel-rail o-rings, they were rotten too.
I never really "bonded" with this bike.  Nothing but V-motors on streetbikes for me from now on.
rubber side down,
Derek
93 Cali black & red
Offline Outback_Jon
« Reply #3 on: November 12, 2011, 06:59:56 AM »
Sounds like the carbs really need a complete overhaul.  Everything replaceable being replaced.
Offline Motor Head
  • Resurected Concours, $260 Purchase & Counting
« Reply #4 on: November 12, 2011, 07:28:37 AM »
 Before making Jetting changes, the basics must be correct. Maintenance adjustments completed.  Ignition system checked, valve adjustment, and compression test, all would be a good Idea to insure engine is correct. Fuel Level in the carbs must be checked, and set if necessary. It would be best to make sure the Carbs have not restrictions, or damaged parts, such as blocked jets, air bleeds, transition circuits. Torn or leaking slide diaphragms, or Air-cut diaphragms. Vacuum leaks between Carbs and engine must be eliminated, also Air leaks between Carbs and Air-Box.
 So jetting for the A5 model is in the Supplement section of the FSM. You may have the Later model. But here this info is, and nowhere is a 138 main mentioned.
There are a couple of very cheap ways to make sure your Ignition is up to it. First Check both the Primary and Secondary resistance of both coils, and then the Boot that attaches to the plug, as it contains a resistor. If you have the Original plug wires, get new 7mm hypalon plug wire, available by the foot and 4' is plenty. You can replace it easily for a couple of bucks. Don't run a Spark plug that has an "R" in the part # as these are resistor plugs, you already have a resistor in your Boot that goes down on the plug. So D8ES, not DR8ES. This will give a Hotter Spark, simple stuff. Taking plug readings, after this work will show if it is rich.
« Last Edit: November 12, 2011, 08:41:06 AM by Motor Head »
1990 ZG1000 C10
1982 KZ1000 LTD
« Reply #5 on: November 12, 2011, 01:48:41 PM »
Moved from another discussion.
Whatever a person does, they need to find jetting that is the best for both worlds.
Years ago I jetted for a ride in Colorado. Worked great but was awful when I returned home to Houston.  I clearly jetted too lean when I did mine.
Rejetting is a heck of a lot of work to do if you change altitudes a lot.
Soo,,,, my thought is (a person might be able to jett extra lean for Hi Altitude and add restricter in the airbox when you go down to the flatlands....)
My thinking is this might give you the best of both worlds..
Is this a viable solution?
 By the way, Steve join in with your thoughts.
    Have you already built a 2 min kit for altitude and do you recommend changing restriction if you use that kit at lower altuitudes?
In my case, I'm (Flatlander) going to install a 2 min Jett kit in my bike that Steve put together for use with his performance Cam.
If I get the chance to go up to higher altitudes again, my plan is to remove/reduce the restrictor.
« Reply #6 on: November 12, 2011, 01:50:00 PM »
Rick
Rick, I always assumed that Sam was Jetted special for Colorado. I am suprised as you go like heck!!
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #7 on: November 12, 2011, 03:20:14 PM »
135 and 38 isn't even stock cA jetting, stock CA jetting is 130 and 35.
I have my jets kits set up for altitude also, theres several of them running in your area, and I've gotten feedback of high 40's to 50 mpg from them. While your jetting is definitely an issue fuel level will also be an issue, especially if the bike has any age to it. Steve
Offline Outback_Jon
« Reply #8 on: November 12, 2011, 03:59:20 PM »
Just out of curiosity, has anyone that changes altitudes a lot installed a Dial-a-Jet system on a Concours?
« Reply #9 on: November 12, 2011, 04:18:39 PM »
dial a jet is junk. sorry, just the facts - Steve
Offline Outback_Jon
« Reply #10 on: November 12, 2011, 05:38:09 PM »
Nothing to apologize for.  Like I said, it was just out of curiosity.
Offline AZBiker
    • My photos
« Reply #11 on: November 12, 2011, 09:22:22 PM »
Good to know, I've seen them advertised for years.
rubber side down,
Derek
93 Cali black & red
Offline AZBiker
    • My photos
« Reply #12 on: November 12, 2011, 09:32:28 PM »
I'm gonna be pulling the trigger on your 2 min mod jet kit next payday.  I don't have the patience to screw with this and reinvent the wheel.
BTW, the only replaceable parts of the carbs that aren't new are the jets, the floats, and the diaphragms.  I've already done the float needles, air cut valves, and fuel rail o-rings.  Removed my fuel screws and they look fine.
I've even got the gauge to check my fuel level when I get them back together.  I'm going to check the static float height with a small mechanic's rule before I put the carbs together.
I'm planning on using iso-heet as the liquid to check my fuel height.
I laugh now when I see a 4-cylinder on Craigslist that "just needs a little carb work."
rubber side down,
Derek
93 Cali black & red
« Reply #13 on: November 13, 2011, 07:29:27 AM »
You'll like this kit, it works well. You may want to get with Jim Snyder and see if he wants to make an adjustable blockoff plate for you if riding at sea level is a concern. You can just use a larger foam block at lower altitude, but Jim's adjustable plate would be a cool, permanent solution. Steve
Offline Sparkie
« Reply #14 on: November 13, 2011, 09:02:56 AM »
OK just saw this. I have some experience with high altitude jetting in Flagstaff, Az. (7000'). I started with stock cali jetting which was a 130 main and 35 pilot. I changed to SISF orig jet kit which leaned out the main jet mostly. The main jet now is somewhere around a 120 or next size leaner, (Steve's trade secret). I didn't use the needle shim as I don't need that at my elevation, per SISF instructions also. With these changes and adjusting the fuel idle screw (close to 1 3/4 turns out) my bike runs like a whole new animal. It really smoothed out the low end throttle response and I consistently get 47-53 mpg. When I do ride at lower elevations down to sea level the bike still performs very well. There is a slight difference in that low end throttle response at sea level. Its not quite as smooth then as back home. The top end hauls a__ compared to stock. I'm also running SISF exhaust sprocket which is also an amazing boost to low end power. But I'm very happy with these jetting changes at both 7000' and when I go to lower alevations. I don't think his kit that I'm running was really even designed for higher elevations but its a huge impovement over the stock jetting. I would probably benefit from blocking my air intake at lower elevations but I haven't experimented with this. I did try blocking the intake at 7000' and did not like the effect. My personal feeling is I don't want to be restricting air flow at 7000', its already happening. Hope this helps, Mark
Offline Motor Head
« Reply #15 on: November 13, 2011, 09:54:23 AM »
Sparkie,
 While I think the OP has it under control.
 I and others appreciate the Post on the Jetting. Especially the Down to Sea Level info.
 Main Jets are only $1.60 from one of my suppliers.
« Last Edit: November 13, 2011, 01:40:18 PM by Motor Head »
1990 ZG1000 C10
1982 KZ1000 LTD
Offline Roadhound
« Reply #16 on: November 13, 2011, 10:56:36 AM »
Good Point, and those $1.60 jets actually come with legible numbers on them.
Don Ricks
Atlanta, Ga.
Offline Sparkie
« Reply #17 on: November 13, 2011, 11:09:40 AM »
I have no problem at all buying a jet kit from someone like Steve who has done all the work including dyno time. I could blindly start buying jets and changing them but I have no access to a dyno where I live. The small price I paid was well worth it for the results and performance gains. Mark
Offline Roadhound
« Reply #18 on: November 13, 2011, 11:22:44 AM »
If you are happy with that, great. IMO if I purchase a part, it's mine I paid for it and it should come with all markings and numbers intact.
Don Ricks
Atlanta, Ga.
« Reply #19 on: November 13, 2011, 12:30:20 PM »
Hey, you wanna do all the work I've done to replicate my work? knock yourselves out. Keep in mind the time I've spent, the WBO2 sensor I purchased, the dyno time I paid for, and the tester bikes I've worked on or provided parts to. Keep in mind that nobody would get the benefit of the 2 minute mod jetting had I not stumbled onto it while dyno testing, and worked it though, as the whole concept of blocking the intake to make more power is completely against common intuitive sense. Do I make money when I sell a jet kit? Yes I do. I worked for that money. When you go to work, you expect to get paid, why would you expect less from me?
   Also, if you don't feel my product works, or is to expensive, or you don't need it, whatever, just don't buy it. Simple as that. Steve
