Author Topic: Cant get key to turn  (Read 26795 times)
Re: Cant get key to turn
« Reply #30 on: February 16, 2012, 09:41:19 pm »
On the image I posted showing how the FOB works, it mentions above that about possibilites of intereference from other radio sources (seeing as your batter checks out).  Try moving the bike and see if that helps.
It is very unlikely anything will interfere with using the passive RFID.
Offline Glennn
    • Metric Rider
« Reply #31 on: February 16, 2012, 09:54:14 pm »
Hmmm, good point.
1999 Yamaha Road Star
Canberra, Australia
CDA #390
Offline Kurt
« Reply #32 on: February 16, 2012, 11:54:24 pm »
You may have the 'stuck KiPass activation switch' problem. If  there is voltage at the battery (or anywhere else on the bike) and absolutely nothing happens when you press the key down, the switch might be stuck.
Take off the top / left side fairing cover- the black one just under the left handlebar. Under that cover is a wiring harness inside a rubber boot- find the dark gray, eight- pin connector inside that boot and disconnect it. Reconnect it and if the dash lights up, you have a stuck activation switch. If there is a valid fob within range, and the dash lights when you reconnect that connector, turn the key to 'on' as soon as you plug it back in- you will only have something like 5 seconds or so. Then start the bike normally. You will have to break that connector and reconnect it each time you want to start the bike until you have the ignition switch assembly fixed at a Kawasaki dealer but that work- around WILL work to get the bike running as long as your problem is a stuck activation switch.
Best of luck and let us know how that works out. If you still have a problem post up again and I am sure someone will help you out. I will check back in later tonight and see if you posted anything else.
Brian -- You NAILED it!!! I was able to get the motorcycle running this evening using the steps that you outlined. Tomorrow I will ride to the dealer in San Diego and get the motorcycle fixed. Yes, I will have to cancel the rest of my ride, but at least I get to ride my motorcycle to be fixed rather than have it towed!!
To the doubters: My offer stands. Anytime anyone would like to come by my house for dinner, coffee, or tire kicking, or if anyone needs a place to stay while riding, please get in touch.
Again Brian, thank you!
« Reply #33 on: February 17, 2012, 12:15:40 pm »
Wow.   That was a great idea.   I am surprised nobody else suggested that.   :o
Offline jjnorc
  • 2009 C14 Non-ABS. Red.
« Reply #34 on: February 17, 2012, 03:36:38 pm »
Brian hooked me up with a great Rhode Island dealer, who did the heavier spring upgrade, and I haven't had an occurrence since then.
I'm very interested in how the switch upgrade is done.
Does anyone know or has anyone done the upgrade?
I have an 09 and have never had a problem but I'd like to be practive.
Because turning doesn't suck.
« Reply #35 on: February 17, 2012, 03:37:38 pm »
Seriously Kurt, do not cancel the rest of your ride. Keep going. I doubt it will fail again and you have proven you know how to get around it. Don't let KiPass win and shorten your ride.
« Reply #36 on: February 17, 2012, 03:40:16 pm »
From what we've seen, us mere mortals aren't allowed to possess these special unobtainium springs.
Northern Illinois   Silverdammit '08 C-14 ABS
« Reply #37 on: February 17, 2012, 03:43:37 pm »
Thanks for this Brian, saved to Evernote so I can access it anywhere.
If you guys are Android users, or maybe even iPhone users, Evernote is pretty handy.
No affiliation.
« Reply #38 on: February 17, 2012, 03:48:17 pm »
'practive'?
"LOCTITE┬«"  The original thread locker...  #11  2020 Indian Roadmaster, ABS, Cruise control, heated grips and seats 46 Monitoring with cutting edge technology U.N.I.T is Back! 2008 C14 Moved on to a new home, 2016 RM traded in.
« Reply #39 on: February 17, 2012, 03:50:04 pm »
'practive'?
That's like proactive but not.  ;)
Offline Jimmy Lucas
« Reply #40 on: February 17, 2012, 04:07:49 pm »
i'm new to the concours 14, got a well used 2008 model recently and am really liking it, is this issue only on the new ones or on the older ones too?
« Reply #41 on: February 17, 2012, 04:57:07 pm »
I don't think so and possibly...
I may be revising this prognosis.....
« Last Edit: February 19, 2012, 06:47:33 am by VirginiaJim »
« Reply #42 on: February 17, 2012, 05:09:07 pm »
Actually, its so hard to tell but we all like to think the issue is with the older ones and not the newer ones. Seems like there have been fewer reported cases from the 2010's and beyond, than with the 2009s and before.
« Reply #43 on: February 17, 2012, 06:02:51 pm »
Well, the problem showed up on '08's and has continued through to at least the 2011 models (see the thread about the guy stuck in Mexico with a new 2011- http://www.zggtr.org/index.php?topic=6941.0 ). There have not been any part number changes on the 2012 that I can see so..... ?
Offline Jay
  • 1979 Kawasaki KZ1000ST
« Reply #44 on: February 17, 2012, 08:17:10 pm »
You Da Man!
- 2011 Kawasaki Concours 14, Black
- 1979 Kawasaki KZ1000ST (Shaft Drive)
- 1976 Triumph Bonneville 750
