Author Topic: Bearinged up shifter  (Read 28393 times)
Offline kzz1king
Re: Bearinged up shifter
« Reply #120 on: September 03, 2019, 02:18:24 PM »
Well I cant leave well enough alone so I ordered one. Time for oil change so shifting is not as smooth. Going to try this out before oil change just to see if any difference.
Wayne
2010 CONCOURS
1974 Z-1
« Reply #121 on: September 03, 2019, 03:59:39 PM »
Well, don't tighten it to 20ftlbs like I did...
« Reply #122 on: September 04, 2019, 07:03:50 AM »
fyi; When I installed my bearinged up shifter it would move in and out slightly {as the bearings were not tight in the shifter}.
  {I think this may be what caused the gap that Maxtog had}
Murph had me put Loc Tite on the OD of the bearings.
   (I think I used Surperglue Gel as that was what I had)
That prevented that little movement of the bearings inside the shifter.
Problem solved.
« Last Edit: September 04, 2019, 07:45:49 PM by connie_rider »
« Reply #123 on: September 04, 2019, 03:34:49 PM »
fyi; When I installed my bearinged up shifter it would move in and out slightly {as the bearings were not tight in the shifter}.   {I think this may be what caused the gap that Maxtog had}
Murph had me put Loc Tite on the OD of the bearings.    (I think I used Surperglue Gel as that was what I had) That prevented that little movement of the bearings. Problem solved.
I was under the assumption that the movement meant that it wasn't tight enough.  There certainly isn't any movement now. :/
Offline kzz1king
« Reply #124 on: September 16, 2019, 05:25:29 PM »
Well I finally got to test the bearing up. 12 days of a nasty virus. Finally feeling a bit better. My bike had a lot of slop. with over 60,000 on it it is understandable. The little plastic bushing was badly worn. Bearings fit nicely in mine. Did toss in a little loctite.
A great improvement on my bike. Real happy with it. May not be needed but if you have a high mileage bike and your shifter flops around.........
Wayne
2010 CONCOURS
1974 Z-1
