Author Topic: New cans = carb adjustment/rejet ?  (Read 3199 times)
Offline wild4stangs
« on: April 03, 2012, 03:31:29 PM »
Greetings all, I am looking at a set of aftermarket slip on's... If I get them, does that mean that I have to mess with the carbs ? I already have the stock exhaust with the bafflectomy mod...
01 Yamaha Roadstar Silverado
94 Wineberry Connie
Offline Daytona_Mike
Re: New cans = carb adjustment/rejet ?
« Reply #1 on: April 03, 2012, 05:40:33 PM »
To be honest your   stock carbs already need to be re-jetted  to improve performance and economy and you really  need overflow tubes (do a search on Hydro lock)
The only thing your going to gain with slipons  is less  weight both on the bike and your wallet. You wont get anymore power than you already have other than  the above recommendation.
Read this: http://sites.google.com/site/shoodabenengineering/intake-and-exhaust
If you want the best value for your money do the  Performance Exhaust Cam Sprocket and the Carb 2 minute Mod or get the full set of cams.
If you have money to burn and you just want loud and looks (you wont make any more power) Delkavic makes nice slip ons  or you can get Dale Walker Hole Shots.
Offline wild4stangs
« Reply #2 on: April 04, 2012, 11:17:54 AM »
I am looking at sound, looks and weight reduction more than raw performance. I think my Connie runs a bit fat anyway, I just don't want her to be too lean....
94 Wineberry Connie
« Reply #3 on: April 04, 2012, 11:34:20 AM »
What Mike said is true. To get optimum performance, Steve has worked out jetting that will improve things.
But you do not have to do a rejett. Bike will run fine after you change the mufflers.
I installed Cobra's on 5 Connies. None were rejetted. All ran fine.
Note: I am preparing to rejett mine now.. I installed more than just mufflers and want to improve the jetting...
If you decide to rejett with Steves parts, let him know you have different mufflers (etc). He may tweak his jett kit for you.
He tweaked the jetts he sent me....
« Reply #4 on: April 04, 2012, 11:39:37 AM »
You are right the Concours is jetted a little on the fat side and can usually take a set of slip-on cans without the broken record warnings; truthfully for as hard as I actually ride my bike  the only mod I really needed was the Staintune mufflers to please my own ears if no one else's.
« Last Edit: April 05, 2012, 06:11:25 AM by T Cro ® »
Offline wild4stangs
« Reply #5 on: April 09, 2012, 08:19:08 AM »
Thanks folks... I will receive the cans in a few days... I am really thinking of having Steve do up my carbs... I really like his approach... I will install the cans and take her for a couple long rides and see what's what.  Just hate to have her down during the good riding weather.  Does Steve just work on what you send him, or can I order a set of carbs already done, and just send him mine as a core ?
94 Wineberry Connie
« Reply #6 on: April 09, 2012, 10:54:23 AM »
He does only yours.
His turnaround time is great though.
He'll do the work and return them to you quickly.
« Reply #7 on: April 09, 2012, 11:22:00 AM »
VERY
Offline red44
« Reply #8 on: April 09, 2012, 07:01:54 PM »
Yup, he gets them done quick and right back to you.
Offline SteveJ.
« Reply #9 on: April 11, 2012, 07:56:52 PM »
Hey SiSF, correct me iff'n I'm wrong, but they almost never spend 48 hours at his shop, unless something is messed up really bad.
America's Seaplane City
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #10 on: April 13, 2012, 05:19:13 AM »
I strive for a very quick turn around, generally back on the way home in 2 days. This week I am at the end of doing 7 sets, and all but one that had a fuel needle seat issue that wouldn't cooperate while setting fuel heights have been within my quoted timeline. It wasn't easy, early mornings and late night, but the ultrasonic sure made the difference - it's cleaning one set while I'm dissassembling and prepping the next... Steve
