Author Topic: Driving lights installed.  (Read 6945 times)
Offline jqram35
  • 2012 C-14 Candy Arabian Red
« on: April 22, 2012, 04:37:54 PM »
Real Time LED lights installed on Big Buck mounts. Have to get some night pics of brightness.
Jeff
Offline jqram35
Re: Driving lights installed.
« Reply #1 on: April 22, 2012, 04:45:38 PM »
dark garage duh.
Jeff
« Reply #2 on: April 22, 2012, 05:18:07 PM »
dark garage duh.
If that is what they look like to oncoming traffic, I hope you have them tied into the high beams and treat them as such!  :)   Or maybe they are just not final aimed yet?  Or they just scatter a LOT??
Offline jqram35
« Reply #3 on: April 22, 2012, 08:16:26 PM »
Jeff
« Reply #4 on: April 22, 2012, 08:47:38 PM »
[pics]
Hmm.  Well, it does look like they have nice, well defined, round beams.  But you also have the beams WAY above the low beams line, which is a huge "no-no" if they are on with the low-beams!  (And here it would be illegal and also fail state inspection... and for good reasons, it will blind oncoming traffic).
My suggestion would be to either keep the beams like you have them, but make sure they are wired into the high-beam only circuit, or dramatically lower them, and also spread them apart a bit.
Offline jqram35
« Reply #5 on: April 22, 2012, 08:53:52 PM »
Too wiped out to mess with them tonight I am going to lower them and spread them out a bit. You must live out West or up East in Nazi land. Here in South MS where only one tail light is all that is required it wont be an issue LOL. Frankly I don't ride much at night and these have an off switch. I am amazed at how bright they are for LEDs
Jeff
« Reply #6 on: April 22, 2012, 09:26:52 PM »
I know how THAT goes
East yes; mid-Atlantic (Virginia)
Well, like you, I am probably less concerned about law and more concerned about my fellow drivers.
They are pretty impressive.  LED's have been improving quite rapidly.  Just today I replaced all my tracklighting with LED bulbs- they finally hit an affordable price while being a tolerable color (Unlike CFL, they are fully dimmable, fully X10 compatible, create no RFI, come on instantly at full brightness, are more compact, have no mercury, and give off no UV)
Offline Elfmaze
« Reply #7 on: April 23, 2012, 03:48:44 AM »
Real times lights are not dimmable correct?
Offline jqram35
« Reply #8 on: April 23, 2012, 05:20:07 AM »
They don't come with a dimmer. I guess one could be rigged up but not sure. They do have a 3 led versions that is dimmer.
Jeff
Offline Caffeinated
« Reply #9 on: April 23, 2012, 09:51:03 AM »
Yes, you can use a dimmer. Read through this thread... http://www.zggtr.org/index.php?topic=207.0 there is a wiring diagram and parts needed for dimming.
2012 Black Concours 1400
« Reply #10 on: April 23, 2012, 02:49:42 PM »
I am not quite sure why someone would want to dim driving lights.  As long as they are aimed properly, why would you want to run them at less than full brightness?  And if they are aimed wrong, dimming them doesn't really fix the problem.
Offline jqram35
« Reply #11 on: April 23, 2012, 05:14:45 PM »
No plans to install dimmer...
Jeff
Offline Caffeinated
« Reply #12 on: April 23, 2012, 05:18:34 PM »
If you want to use them as day run lights, and not annoy oncoming traffic, yet still have the option of full blast with your high Beams on.
« Reply #13 on: April 23, 2012, 06:22:02 PM »
Oh.  Hmm.  In that case, it would be ideal to have a circuit that could automatically put them into 100% if high beams are activated and drop to 10% or something if low beams are on.   Shouldn't be too difficult.  I volunteer you to make it for him :)
Offline Elfmaze
« Reply #14 on: April 23, 2012, 06:31:26 PM »
I saw another cool mod where a guy also linked his horn button to the driving lights, So a beep of the horn also flashed them.   I hardly ever use my horn though.
But yes,  the idea is for around town and such you still get the benefit of the "triangle of light" without blinding cars and oncoming cops.  But also have some useful light ready in a pinch.
Offline gildaguz
« Reply #15 on: April 23, 2012, 06:34:13 PM »
Here is a piture of mine
2009 Non ABS Concours Black
2004 Honda Shadow  Sabre 750
1979 Suzuki 185 all terrain
Offline Caffeinated
« Reply #16 on: April 23, 2012, 07:16:45 PM »
Yep, that's what the thread I referenced spells out. Exactly how to set it up so with the low beams on the lights are at whatever % you set it at, and when the highs are hit, they automatically go 100%. It also wires in a switch so you can switch them completely off if you want. It's on my list of things to do when time and $ are more readily available.
Offline Hayeshfc
« Reply #17 on: April 23, 2012, 09:11:28 PM »
I like the mounts - where did they come from (A big buck mount search sends one off into the netherlands of taxidermy......)
Offline jqram35
« Reply #18 on: April 24, 2012, 06:45:41 AM »
Jeff
Offline Elfmaze
« Reply #19 on: April 24, 2012, 07:18:42 AM »
OK is it just me or do the mirror hanging lights remind you of diamond earrings for Connie?
