« Reply #1 on: May 23, 2012, 09:41:47 AM »
Good info Steve. My cable is fine but I've managed to break the adjuster at the end of the cable housing because I had it mounted up too high and my fuel tank sits right on top of it. At some point it snapped the threaded adjuster. It still works fine and holds speed correctly but at least it looks like I can repair it some day if I need to since that universal kits appears to contain an adjuster that might work.
Marlan
![](http://zggtr.org/Themes/default/images/ip.gif)
Logged
