Author Topic: '08 C14 Dyno Run  (Read 12375 times)
Offline TRBN
'08 C14 Dyno Run
« on: May 28, 2012, 06:04:46 PM »
Here is my Dyno run from over the weekend.  Temps were around 96deg at 75% humidity.
'08 Concours14 -- 150.8HP 100.3ft lb torque
Vance&Hines CSOne Slip On
Throttle Position Sensor tweaks to fix a lean surge condition (Done by dealer)
Aaron E.
Offline reesedp
  • Sail Army
Re: '08 C14 Dyno Run
« Reply #1 on: May 29, 2012, 11:39:54 AM »
LOVE it!!
Offline Mister Tee
« Reply #2 on: May 29, 2012, 11:48:39 AM »
So that translates to 170 - 175 hp at the crank.  Not too shabby!
Offline Bourne2Ride
« Reply #3 on: May 29, 2012, 12:25:14 PM »
That's sweet! nice couple of runs. Mine's bone stock; but she has enough power for me.
- Heroes
« Reply #4 on: May 29, 2012, 03:57:20 PM »
That seems high for what is a basically stock Concours 14.  A slip-on shouldn't make much difference, alone.  Are you running a commander or a reprogram of the ECU or something??
Offline jjsC6
« Reply #5 on: May 29, 2012, 04:16:57 PM »
I agree it seems high - seriously high.
Jim
2010 Concours - Sold Feb 2013
Current bikes....
« Reply #6 on: May 29, 2012, 08:45:31 PM »
Yep...
Offline TRBN
« Reply #7 on: May 30, 2012, 10:29:47 AM »
Nope, just the Throttle Position Sensor  tweaks.  I definitely noticed a change in power after the tweaks and a major drop in MPG....
Aaron
Offline Fretka
« Reply #8 on: May 30, 2012, 10:34:09 AM »
What's going on at 3500 rpm? Did the dyno guy comment on this?
Prolly rear wheel losing traction early on.
« Last Edit: May 31, 2012, 11:53:19 AM by Fretka »
Offline Supatramp
« Reply #9 on: May 30, 2012, 10:34:50 AM »
I definitely noticed a change in power after the tweaks and a major drop in MPG....Aaron
From what to what?, curious
Offline TRBN
« Reply #10 on: May 30, 2012, 12:24:15 PM »
He did not say about the humpty at around 3500rpm...he did comment that the AFR was lean up to about 30% throttle and then rich at the very top end of the RPMs.
Aaron
Offline TRBN
« Reply #11 on: May 30, 2012, 12:25:18 PM »
Mileage went from 40-44 MPG pre-tweaks to 33-37MPG post-tweaks.
Aaron
« Reply #12 on: May 30, 2012, 03:32:07 PM »
Granted, I don't read every post or thread, but I have never heard of "tweaking" the TPS before.  Can you elaborate any more about what was done?  I am assuming this is some type of physical movement of it?  It just doesn't sound like a good idea.... if the TPS is lying to the ECU, the pre-programmed mixes might be way off.   It is not like a reflash/reprogramming of the ECU for performance, where the curves are carefully tweaked over the entire load/RPM band to match a more ideal setting for the actual bike, while looking at diagnostic equipment...
« Reply #13 on: May 30, 2012, 03:47:36 PM »
My master race mechanic friend also told me to point out that "Dyno numbers can be all over the place (inaccurate)"  and "At 96F temp, the correction factor will be huge. Correction factors are developed on averages. Not all motors respond the same."
Further, he pointed out that the graph doesn't say "WHP", which is what would normally appear for a wheel horsepower (which is to the ground).  150 is not outside of the "normal" range for the Concours *crank* horsepower.  In fact, my specs show 153 as the claim, WITHOUT ram-air (157.7 with).  Doesn't mean the graph is actually estimating WHP, just saying that is another possibility.
Offline capt chaos
« Reply #14 on: May 30, 2012, 03:50:24 PM »
Here's my '10 model with Vance & Hines and ECU reprogrammed dptune.com
http://flic.kr/p/9TDiyK
2010 GTR1400 Magnesium
Offline Mister Tee
« Reply #15 on: May 31, 2012, 09:46:56 AM »
Yeah but the only way to directly measure crank horsepower is to remove the motor and hook it up directly to a dynamometer.  That would take some doing for a motorcycle engine.  Most if not all motorcycle dynamometers measure wheel horsepower.
« Reply #16 on: May 31, 2012, 05:01:28 PM »
Of course, but that doesn't mean the particular software used wasn't set to "estimate" the crank HP.  I know, that seems crazy, but I don't put anything past anything anymore :)
