Author Topic: Has anyone ever converted their headlight (9003) bulb to a newer LED style bulb?  (Read 6915 times)
Offline Eydugstr
Would there be any issues in doing this, provided you don't exceed the wattage of the stock bulbs?
Offline nevadazx12
I tried, the stumbling block was the retaining clip.  The big heat sink cooling fan portion of the bulb interferes too much with getting that clip hooked up properly.  I ended up going back and installing the H4 halogen.
1986 Connie
1974 BMW 90/6
1964 Triumph T100SC
I recall reading about a few of the assemblies that showed the heatsink could easily be removed, and reinstalled after the bulb was locked in, not sure which mfg products they were, but they showed pulling the units parts apart, and reassembling...
Offline SteveJ.
I used an Evitek brand LED for the c10 and the KLR. There is a separate base. Easy peasy and they work very well. Good pattern and excellent cut off on low beam to keep from annoying/blinding oncoming traffic.
America's Seaplane City
Offline ddavid
Would you happen to have a part or model number for the Evitek LED light?
Offline SteveJ.
https://www.amazon.com/Evitek-Headlight-Bulbs-Motorcycles-9003/dp/B017M566T4
$47.99 for a pair.
PS. Sorry about my tardiness, good luck. I just put one in the low beam housing on my new Versys.  :thumbs:
Offline mellow yellow
I just use the sylvania silver star bulbs from walmart. my riding buddy said that my headlight was very bright.
Offline mikeyw64
  • Country: wales
Havent seen the back of a C10 headlight but I reckon from your description the ones I used on the C14 would get around this as the heat sink is removable for getting the clips on
http://www.zggtr.org/index.php?topic=22202.0
Recent posting on our other forum had good revues on this
http://stores.advmonster.com/h4-r3-led-headlight/
And I can say I may try them out on my bikes when I need my next bulb...
Its a standard base, and uses less power, a win win...
Offline datsaxman@hotmail.com
Even the LEDs that do not have detachable housings will fit.
It takes a little dexterity, but they will go on.
You have to thread the wire in AS the LED is going in to the socket.  (easy now...)
The rubber boot might be a different story.  I trimmed mine back a bit.  Now they fit.
YMMV of course.
dsm
161.5RWHP on the dyno
Formerly Silverdammit!
